new leaf springs or AAL
Discussion in 'Suspension' started by mgfab3, Aug 22, 2019.
  1. Aug 22, 2019 at 11:12 PM
    mgfab3
    mgfab3 [OP] Well-Known Member
    My original leafs are sagging bad, almost got a bro lean. Truck had the TSB when I got it, so four leafs currently. Question is should I replace the springs or do an AAL? and which brand/setup would be recommended? Currently have bilstein 5100 all around, wont mind if it a little higher in the back
    Thanks
  2. Aug 22, 2019 at 11:41 PM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
  3. Aug 24, 2019 at 9:36 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Sounds like if the stocks are worn out you should get a completely new set. From what’s Headstrong Off-road has told me AAL is a good option for trucks with leaf packs in newer to decent shape.
  4. Aug 30, 2019 at 1:05 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    OME Dakar EL095R and never look back. Pull the 3rd leaf down for less lift, it'll leave you with a 4+1 pack. Works great and rides well. Goes perfect with my Baja/Pro lift and maintains rake. No vibes either
  5. Sep 2, 2019 at 1:04 AM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    If you don’t really need a lift over stock you could probably pick up some takeoffs from a 3rd gen for next to nothing. I see them for $100-200 with almost no miles all the time on CL.
