New Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Mar 29, 2014.
  1. Mar 29, 2014 at 8:52 AM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    So I am trying to do some research before I purchase anything but I am looking to buy new leaf springs for my 2003 Toyota Tacoma 4x4. I have looked around the web and found brands like skyjacker, which are quite expensive... $450 for a pair?!
    I searched the forums and have found that Dorman 929-401 springs are reasonably priced, more like $125 a spring, yet they are for 1998-2000 tacomas. Will the Dorman 929-401 springs even fit my 2003 tacoma?
    If anyone else has any suggestions in brands or types of leaf springs that are reasonably priced let me know!!!
    I am running stock everything, so just normal leaf springs would be good. The stock toyota ones are for lack of a better word, dead. Still rides well and all that but bumps and the many potholes in Pennsylvania are getting to be a little rough. I also have the typical tacoma lean..
    Thanks for your help,
    Tom
  2. Mar 29, 2014 at 5:36 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    partsgeek has those for 107 a piece with free shipping.. they will work fine, only the 95-97 use different (shorter) springs
  3. Mar 29, 2014 at 6:44 PM
    Tjsingle26
    Tom
    PA
    Thanks for the reply. so the 98 and up tacoma's use all the same length springs?
  4. Mar 30, 2014 at 9:28 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    02 Dbl cab Lunar Mist
    Some of this Some of that
  5. Mar 30, 2014 at 9:45 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Keep in mind that the stock driver-side leaf pack has a slightly higher spring rate, to allow for the extra weight on that side (gas tank, driver, front differential, etc). Some aftermarket companies allow for this difference, but not all.
    Be sure that your new pack has anti-friction pads between the leaves, to reduce squeaking and excessive metal-on-metal wear.
  6. Mar 30, 2014 at 10:58 AM
    Tjsingle26
    Tom
    PA
  7. Mar 30, 2014 at 10:58 AM
    Tjsingle26
    Tom
    PA
    Yeah, I noticed that with the dorman ones, I want to correct the lean in my truck that is already there!
  8. Mar 30, 2014 at 11:11 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    My allpro's were the same (not driver specific) but i isntalled 1/4" top plate spacer on front strut to correct the lean
