New Leafs - Creeking Noise!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Feb 4, 2014.
  1. Feb 4, 2014 at 6:27 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Just installed some new leafs. I hear creaking noise when ever I go over a bump or whenever the leafs move. Anyone else experience this? Should I blast the leaf with some kind of oil like WD40? Thanks.
  2. Feb 4, 2014 at 6:35 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Its not uncommon. What springs are you using? Did you grease the shackles? Make sure your shackle bolts aren't too tight.
  3. Feb 4, 2014 at 8:16 PM
    Zer0
    SGV, California
    99 PreRunner
    Thanks for reply. Im using dorman 929-401 leafs. Is the shackle where the u-bolts bolt onto? I dont think theyre too tight. I used air tools to tighten. I didnt rack them too hard. How tight should they be?
  4. Feb 4, 2014 at 9:37 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    You need to properly torque stuff.. air tools will get them tight btw you still need to grab a torque wrench and make sure its all in spec. Then after driving for about 500miles retire again.
  5. Feb 4, 2014 at 9:39 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    The shackle comes down from rear bumper area and attaches on to the leaf eye..
  6. Feb 5, 2014 at 8:07 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Do those spring packs come with anti-friction pads between the leaves?
  7. Feb 5, 2014 at 9:36 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Ubolts should be tight and torqued to spec. Shackles should be snug but not tight to allow unrestricted movement of the shackle. (The shackle is the piece that connects the rear spring eye to the frame).
    If the leaf springs do not have any sort of anti-friction pads between the leaves they will be a bit noisy. Not much you can do there unless you pull the leaves apart and install Teflon pads.
