new LEDs
Discussion in '1st Gen. Tacomas (1995-2004)' started by gainesswink, Sep 8, 2020.
  1. Sep 8, 2020 at 9:37 AM
    gainesswink
    gainesswink [OP] New Member
    Hi just put new LED bulbs in my 02 tacoma. Doesn't switch from high to low beams anymore and the high beam indicator seems to be nonexistent. Anybody know what the problem is or how to solve it?
  2. Sep 8, 2020 at 9:41 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Sep 8, 2020 at 9:43 AM
    gainesswink
    im guessing you dont know
  4. Sep 8, 2020 at 11:24 AM
    tntacomaguy
    tntacomaguy Well-Known Member
  5. Sep 8, 2020 at 11:49 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Taco critter likes this.
  6. Sep 8, 2020 at 11:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did you put in the proper bulb? H4/9003 style with high low? Preferably ones with shields similar to stock bulbs?
    https://www.amazon.com/gp/product/B06XHD78DQ/ref=ppx_yo_dt_b_asin_title_o06_s02?ie=UTF8&psc=1
    Lots of good help here so far. :rolleyes:
    Wulf likes this.
  7. Sep 8, 2020 at 12:08 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Alrighty, this is a fun one! I went through this many years ago when I converted to H4 housings with Hella 110w bulbs. Even though the sealed beam and the H4 bulbs use the same connector they do not have the same wiring. You need to swap two of the wires:
    Verify with a multimeter but this should put you on the correct path. Instead of cutting the factory harness I added a H4 relay harness at the same time to support the larger draw of the bulbs and it was pretty painless to repin the connectors and get things working.
  8. Sep 8, 2020 at 12:10 PM
    Wulf
    rock raisin
    inb4 the LED in reflector housing argument:bananadance: :luvya:
  9. Sep 8, 2020 at 12:27 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Maybe check the high beam fluid?
    Jk. Sorry im no help. Had this issue with some HIDs. Ended up tossing them
  10. Sep 8, 2020 at 3:40 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  11. Sep 13, 2020 at 6:17 PM
    gainesswink
    thanks guys i appreciate it
  12. Sep 13, 2020 at 7:35 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    In order to get the high beam light to work on the dash, there must be some resistance in the bulbs. I added a second second socket, and put an HID bulb in it. That fixes the indicator. @Wulf probably answered the issue with no high low beams. I didn't encounter this.
