New lift kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by finny6944, Mar 26, 2009.
  1. Mar 26, 2009 at 6:40 PM
    finny6944
    finny6944 [OP] Active Member
    walpole mass
    06,xrunner,black sand pearl
    k&n filter
    Well I am looking to buy a lift kit this week and I've been doing some research but still need help. Does this look like a good deal and is there anything else I need? The deal is from tuff country. Thanks alot.
    Dan
    ) Upper strut spacers, 2) Upper strut pre-load spacers, 6) Strut spacers, 1) Rear brake line bracket, 2) Rear add-a-leafs, 4) Rear U-bolts, 2) Differential drop sleeves, 1) Hardware bag
  2. Mar 26, 2009 at 6:42 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    how much of a lift do you want.
  3. Mar 26, 2009 at 6:45 PM
    finny6944
    walpole mass
    k&n filter
    A 3 inch, this is a suspension lift. Would I need new shocks too.
  4. Mar 26, 2009 at 6:47 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Go with 5100's and an aal.........................
  5. Mar 26, 2009 at 6:50 PM
    finny6944
    walpole mass
    k&n filter
    where would I find the 5100 and whats an aal?
  6. Mar 26, 2009 at 6:51 PM
    bajamoon
    STEVE
    Whittier
  7. Mar 26, 2009 at 6:52 PM
    bajamoon
    STEVE
    Whittier
    you beat me.:)
  8. Mar 26, 2009 at 6:52 PM
    bajamoon
    STEVE
    Whittier
    aal=add a leaf.
  9. Mar 26, 2009 at 6:56 PM
    finny6944
    walpole mass
    k&n filter
    Ok I will stay away from spacers! Thanks. Is there a better setup?
    Included in kit:
    FRONT: (2) OME 884 standard/light load front lift coil springs
    Optional med and heavy coils can be selected but require OME N140S shocks sold seperately
    Also includes ToyTec Top plate spacers for a full 3" front lift & (6) top plate studs.
    REAR: (2) 2" lift ToyTec Add-a-leafs by Alcan spring (a long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins
  10. Mar 26, 2009 at 6:57 PM
    Lane Cypert
    Lane Cypert Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    You are wanting to lift an X Runner or Prerunner?
  11. Mar 26, 2009 at 7:00 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    same question i had
    finny6944
    Junior Member
    Gender: Male
  12. Mar 26, 2009 at 7:00 PM
    finny6944
    walpole mass
    k&n filter
    4X4 V6 ACCESS CAB speed...Its an 06 i forget what they call it.
  13. Mar 26, 2009 at 7:00 PM
    finny6944
    walpole mass
    k&n filter
    5 speed
  14. Mar 26, 2009 at 7:06 PM
    finny6944
    walpole mass
    k&n filter
    Toytec seems like they have the best lifts , how does the aal work . Does it replace the stock leafs?
  15. Mar 26, 2009 at 7:12 PM
    slobalt
    slobalt Well-Known Member
    Kyle
    Arlington, Texas
    08 Prerunner SR5 TRD Sport
    Billet antenna, Westin Bull bar, Pro Comp 1069 wheels, BFG A/T's, Panasonic double din, nerf bars, grillcraft grill, ARE lsII tonneau cover, protecta bed mat, k&n intake
    If you were to just run bilstein 5100's with 1.75" of lift up front would that level the truck and allow you to run 265/75r16's? How much higher is the rear of the truck from the factory?
