new lift
Discussion in 'Wheels & Tires' started by Will O., May 8, 2009.
  1. May 8, 2009 at 10:06 PM
    Will O.
    Will O. [OP] Member
    Evans,GA
    03 PreRunner TrD
    2 1/2 inch rough country spacer lift. pioneer premier head unit 2 pioneer premier 8" subs
    i got a question about some rims and tires with my new rough country lift can any body guide me through this please
  2. May 8, 2009 at 11:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    what are you looking for? offroad use or just looks?
    Get a wheel that has a 4.5 or 4" backspacing, and I think you can only run a 265/75 with out rubbing on a 2.5" lift. You can try a 285/75, but you will have to trim some plastic.
  3. May 9, 2009 at 11:58 PM
    Will O.
    Will O. [OP] Member
    Evans,GA
    03 PreRunner TrD
    what is the stock off set on the yota rims and what does a greater off set do. like does it push the tire out away from the hard wear of the truck and stick the tire outside the truck
  4. May 10, 2009 at 12:24 AM
    ETaco23
    Evan
    PNW
    Yeah, a less offset/BS will do that. I believe the stock wheels are a 5.5" backspacing, not sure though... I was rubing the frame at full turn and my UCA with my 285/75's and stock wheels.
