New member and long time lurker. Wheel/Tire Question-
Discussion in 'New Members' started by TacoJim2018, Nov 21, 2018.
  1. Nov 21, 2018 at 11:43 AM
    TacoJim2018
    TacoJim2018 [OP] Member
    James
    2007 Tacoma quad cab 4x4 - Midnight blue
    3" lift
    I bought 4 - 2001-2004 stock Tundra / Tacoma wheels to put winter studded tires on my 2007 Tacoma. WOW did I open a bees nest? Can't mix tire sizes at all because of 4x4 differential and I don't know what lug nuts to get?? Is there a quick answer available.
    irayfz6 likes this.
  2. Nov 21, 2018 at 11:44 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Do they clear the front calipers?
    Sum1 Else likes this.
  3. Nov 21, 2018 at 11:45 AM
    Sum1 Else
    Sum1 Else Well-Known Member
    Welcome Aboard James
    buckhuntin-tacoma likes this.
  4. Nov 21, 2018 at 11:46 AM
    TacoJim2018
    James
    3" lift
    Not a clue if they clear calipers? I'm trying to get the basics before taking it to tire shop?
  5. Nov 21, 2018 at 11:47 AM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    Confused by the questions. Are you asking what lug nuts to get?
  6. Nov 21, 2018 at 11:48 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Lets start from the top here.
    You have a 2007 Tacoma, it's 4x4 so it's the 6 lug model correct?
    You bought a set of 1st gen Tundra wheels which are the same 6 lug pattern so that's good.
    What size wheels are they? Do you have a picture of them?
    If they're OEM Toyota Tundra wheels you'll need M12x1.5 lug nuts with a flat seating surface.
    Like these - (I've never used them myself, just came up first on Amazon) - https://www.amazon.com/KSP-Performa...&keywords=m12x1.5+toyota+lug+nuts+mag+seat+24
    To your comment about sizing, yes all 4 tires should be the exact same size.
    boogie3478 and BlueFalconActual like this.
  7. Nov 21, 2018 at 11:48 AM
    TacoJim2018
    James
    3" lift
    LMAO - TY ALL for the Welcome wagon ;)
  8. Nov 21, 2018 at 11:51 AM
    WillT11
    WillT11 Well-Known Member
    Will
    How bad is it if the spare is a different size and you end up having to use the spare in an emergency situation
  9. Nov 21, 2018 at 11:53 AM
    TacoJim2018
    James
    3" lift
    Wheels are 16" I currently have 17" on and,wanting a winter set. Correct lug nuts and 2 more exact tires is what I need unless the calipers response is a real problem??
  10. Nov 21, 2018 at 11:53 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Also depends on the situation and how far off the sizing is.
    if you're a 4x4 but the mis matched wheel/tire up front and switch back to 2wd if possible. With the truck in 2wd and the mis matched wheel and tire up front no harm will come.
    Some will say you can use it anywhere so long as your diff is open because they can rotate at different speeds without damage for a turn as is, so no problem having a mis matched spare. I would be ok with this in a pinch, but avoid it whenever possible.
  11. Nov 21, 2018 at 11:54 AM
    TacoJim2018
    James
    3" lift
    Thanks,now a new possible problem,lol thanks.
  12. Nov 21, 2018 at 11:57 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
    irayfz6 and buckhuntin-tacoma like this.
  13. Nov 21, 2018 at 11:58 AM
    TacoJim2018
    James
    3" lift
    I'll remember that, Thank You!! No 4x4 with spare ;)
  14. Nov 21, 2018 at 12:01 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    1st gen Tundra wheels will fit (confirmed here - https://www.tacomaworld.com/threads/1st-gen-spare-wheel-on-2nd-gen.522486/ )
    The lug nuts are the same from the stock tacoma wheels on your truck now as they are to the tundra wheels, no need for new lugs if you're currently using the stock lug nuts.
    Make sure your 4 wheels are all using the same size tires and you're good to go.
  15. Nov 21, 2018 at 12:02 PM
    TacoJim2018
    James
    3" lift
    Damn lug nutz are expensive?? Does anyone know exact size I need and possibly a national store with great price on them???
  16. Nov 21, 2018 at 12:03 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    M12 x 1.5 with a Toyota mag seat.
    Should look like this -
  17. Nov 21, 2018 at 12:04 PM
    TacoJim2018
    James
    3" lift
    Bought vehicle with custom wheels and lug nutz,no originals :(
  18. Nov 21, 2018 at 12:07 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6 likes this.
  19. Nov 21, 2018 at 12:15 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  20. Nov 21, 2018 at 1:51 PM
    TacoJim2018
    James
    3" lift
    Another question: Does anyone know if the 2001-2004 stock wheels I'm putting on my 2007 taco have air pressure sensors and or receivers for them and,,,,,,will tire stores still install tires with out them?
