New member/new truck, some questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by wombosi, May 26, 2013.
  1. May 26, 2013 at 6:05 AM
    wombosi
    wombosi [OP] New Member
    Western MA
    1998 Tacoma SR5 2.4 V4 2WD
    Hi All,
    Recently picked up a '98 Tacoma SR5, 2WD, 2.4liter V4 with 132,000 on her.
    I am in the Northeast but truck came from Florida and is ridiculously clean.
    A few days after buying it, the CEL came on, with the 420 code "catalytic system below threshold bank 1" or something like this.
    Have done a bit of reading and seems most likely either the cat or the upper 02 sensor. Going to try to run high-test gas in the next tank and see if it helps.
    What else should I do? No way can I spring for an OEM cat.
    I changed the manual trans fluid yesterday (PITA). Calls for 2.7 quarts.
    Is it true that fluid should be filled until it starts to overflow out the fill hole?
    I put almost all 3 quarts in (spilled a bit and couldn't get 100% out of each bottle given the angle) and didn't get any overflow. Am I OK with what I've put in?
    Thanks guys.
  2. May 26, 2013 at 6:51 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Welcome to TW ! I'm not ignoring your question,I just dunno n'ought to give you the answer...
