New member..truck acting up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dubduc1, Feb 13, 2012.
  1. Feb 13, 2012 at 3:31 PM
    Dubduc1
    Dubduc1 [OP] Member
    Arizona
    06 Prerunner SRT5 sport
    Level kit, 32" tires, rims, trd cat back exhaust, trd intake
    I just replaced my spark plugs which I got from Toyota and everything went smooth. Now when the truck is in gear but at a stop it sits just above 500 rpm then everyone so often it with bog down to just below 500 for half a second and the truck will also shake, also started bucking a couple times around 45. Some buddies think is either a vacuum hose and don't think it's a spark plug issue. Its just funny it happened right after the spark plug change. I need help, any suggestions?
  2. Feb 13, 2012 at 3:33 PM
    acdronin
    acdronin Well-Known Member
    IDK, make sure all the plugs are snug (but not too tight), check for hoses yeah, possibly you might want to reset your ECU as well.
  3. Feb 13, 2012 at 3:34 PM
    acdronin
    oh and welcome to TW
  4. Feb 13, 2012 at 3:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    What engine?
    What sparkplugs ?
    What did you disconnect?
    Do you have Scanguage, can you borrow if not and see if tps changes when this happens?
    Vacum leak is most probably cause but badly installed sparkplug could be also a problem
  5. Feb 13, 2012 at 4:46 PM
    Dubduc1
    Dubduc1 [OP] Member
    Arizona
    Thanks Acdronin, this sight is great! What is an ECU btw? Also thank you blue T, the engine is a 4.0 liter V6, I checked the hoses I disconnected and they are good, the spark plugs are stock oem plugs for that truck... Not sure what the part number is. What's the tps? I can see if I can get one... Does any autoparts store have them?
  6. Feb 13, 2012 at 5:17 PM
    acdronin
    ECU is the truck's computer, you reset it by disconnecting the battery for like a minute or so. I don't think this is the issue but I have had to do this in the past for other things.
    Scangauge is a gizmo that plugs into your truck which mounts on your dash, it tells you all kinds of data about the truck. If the truck is still under warranty and you can't find anything else wrong i would take it back to them.
  7. Feb 13, 2012 at 5:21 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Almost sounds like an O2 sensor needs replacing. They tend to cause the problems you are describing.
  8. Feb 13, 2012 at 5:22 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    when u change out a plug on the v6- drivers side, there is one that is hard to get to. so u either pull the vacumm hose or jam hard against it with the ratchet, so id have a good look at the hoses.
  9. Feb 13, 2012 at 5:43 PM
    badger
    badger Well-Known Member
    07 SR5
    Vacuum leak is my guess too. Recheck the hoses. Did you gap the plugs or just put them in? They should be .040". I don't think a bad plug would cause idle swings like you describe. It would just run crappy.
  10. Feb 13, 2012 at 5:51 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I think there was another member the other day that had this same issue if I remember correctly and it was indeed the vacuum hose as mentioned.
    Welcome
  11. Feb 13, 2012 at 6:16 PM
    Dubduc1
    Dubduc1 [OP] Member
    Arizona
    Awesome thanks guys, I did gap the spark plugs to .040 also. So I will give it a good look at all the hoses.
  12. Feb 13, 2012 at 6:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Check every inch of what you just did. I am thinking loose connector on one of the coil packs or maybe a bad spark plug.
    Sounds like you might be missing on one cylinder when this happens.
  13. Feb 13, 2012 at 7:43 PM
    Dubduc1
    Dubduc1 [OP] Member
    Arizona
    I will do that, I also am needing a new clip for my center council
  14. Feb 20, 2012 at 8:06 AM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    Same thing happened to me. Replaced sparkplugs with NGK LFR6C-11 now it shudders at low idle and even has died on me a couple times. Vacuum lines look good. Doesn't throw a code. Re-did the plugs they were fine. Cleaned MAF. Dunno where to go next.
  15. Feb 20, 2012 at 8:17 AM
    custom90gt
    Colorado
    05 SWB TRD Off Road
    The last owner oiled the filter a few days before I bought the taco. It ran great until I changed spark plugs. I also ran a bottle of fuel injector cleaner through my tank, maybe it fouled up the AFR Sensor or O2s... I would think it would throw a code. It almost feels like a miss when it's idling at about 400 rpms, but get it over the 500 mark and it runs smooth.
    I just cleaned my MAF this morning to see what would happen, nothing different.
