New Muffler Help
Discussion in 'Performance and Tuning' started by harmonius15, Jun 10, 2009.
  1. Jun 10, 2009 at 3:55 PM
    harmonius15
    harmonius15 [OP] Member
    09 Taco
    Will putting a new flowmaster muffler in trigger the check engine light? I'm only swapping the old muffler for a new flowmaster muffler not the whole exhaust system. Its an 09 4.0l V6 double cab. At the garage I stopped by at the guy told me changing mufflers would trigger the check engine light and cause other problems. Is this correct?
  2. Jun 10, 2009 at 3:57 PM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    No the only way it will throw a code is if you remove emission parts from your exhaust system and the muffler is not an emission part.
  3. Jun 11, 2009 at 3:58 PM
    harmonius15
    09 Taco
    So I should have no problems with the engine running lean and triggering the light?
  4. Jun 11, 2009 at 4:00 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    no u will not have problems.. the 02 sensors are way before ur muffler, so ur fine, you will not throw a code
