New Nitto tires!
Discussion in 'Wheels & Tires' started by ajviper7, Jul 2, 2009.
  1. Jul 2, 2009 at 10:49 AM
    ajviper7
    ajviper7 [OP] Well-Known Member
    FL Panhandle
    08 silver TRD OR 4x4 AC
    Nitto Trail Grappler M/T
    Nitto is proud to announce the release of its newest off-road tire, the Trail Grappler M/T. The Trail Grappler M/T combines some of the off-road bite of the Mud Grappler with the on-road manners of the Terra Grappler, to create a tire that is both aggressive and quiet.
    There is no need to comprise off-road or on-road performance any longer, thanks to the exclusive technologies found in the Trail Grappler M/T.
    Off-Road Performance Features:
    - Side wall combines a 3-ply high turn-up construction with a thick rubber compound that cushions the tire and helps prevent punctures
    - Z Groove provides lateral stability and mud traction
    - 3D tapered tread blocks add additional biting edges for stability and traction
    - Balanced void ratio and stone ejectors help clear the tread to provide continuous traction
    On-Road Performance Features:
    - Tread design was developed using advanced sound analysis equipment to reduce noise levels common to off-road tires
    - Two wide steel belts provide a stable base for increased tread strength and uniformity which reduces irregular wear
    - Outer shoulder blocks have reinforced grooves that help maintain block stiffness to further extend the tread life
    - Deep center sipes maintain contact with the road surface in wet conditions
    Visual Features:
    - Two side wall designs on each tire that allow you pick the style that faces the road.
    Click here for more information on the Nitto Trail Grappler M/T.
    The Trail Grappler M/T is available September 2009. Initial sizes will range from 32- to 38-inch overall diameter with more sizes to come.
    Coming September 2009:
    LT285/70R16 E 125/122P
    LT295/70R17 E 121/118P
    35x12.50R17LT E 121Q
    LT285/65R18 E 125/122Q
    LT295/70R18 E 129/126Q
    35x12.50R18LT E 123Q
    LT295/55R20 E 123/120Q
    LT295/65R20 E 129/126Q
    LT305/55R20 E 121/118Q
    35x12.50R20LT E 126Q
    37x12.50R20 LT E 126Q
    *Tire fitment depends on the correct offset/size wheels. Always consult your wheel/tire dealer for correct sizing.
  2. Jul 2, 2009 at 10:51 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Looks good.
  3. Jul 2, 2009 at 10:53 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    wow they look nice :thumbsup:
  4. Jul 2, 2009 at 10:57 AM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Those are sick!
  5. Jul 2, 2009 at 10:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Dang those do look nice. I might have to try a set my next go around.:rolleyes:
  6. Jul 2, 2009 at 11:11 AM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    i may have changed my tire desison once again
  7. Jul 2, 2009 at 11:12 AM
    Delmarva
    Tucson, AZ
    hmm....
  8. Jul 2, 2009 at 11:59 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah well its probably going to be a while since my truck just sits in the garage during the week.:cool:
  9. Jul 2, 2009 at 12:01 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    no 285/75/16? :[
  10. Jul 2, 2009 at 12:02 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    They look good :) Glad to see they found a happy median. Wonder what they'll be priced at..
  11. Jul 2, 2009 at 12:04 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    just copy and paste the actual pic not the code
  12. Jul 2, 2009 at 12:10 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    They look great! Can't believe they don't have 285/75's... :rant:
  13. Jul 2, 2009 at 12:14 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    x2. I've never seen a 4wd that wheels (around here) with anything bigger than a 17" wheel.
    Kinda reminds me of the way the old bfg m/ts looked...
    *** On a side note. This is my 600th post in 1 yr. 3 months. I spend way to much damn time on here... but i think its a good thing
  14. Jul 2, 2009 at 12:25 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    I like the 285/70r16 size, but why are they all E rated???
  15. Jul 2, 2009 at 1:49 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Where's the 285/70-17? What's an "E" rating mean?
    Bad ass looking tires though. I hope they get good reviews.
  16. Jul 2, 2009 at 2:21 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    That's a nice looking tire! Two months...hmmmm....
  17. Jul 2, 2009 at 2:32 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Those look sweeeeeeet! I wonder how they will perform.
  18. Jul 2, 2009 at 2:39 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    It really bother's me that you can't get their most popular tires for a 15" wheel......lame......mud tires for mall queens.
  19. Jul 2, 2009 at 2:43 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    no 285/75/16 or 265/75/16??? Not impressed...i'd rock em though :)
  20. Jul 2, 2009 at 2:44 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    ...and no 265/75-16. I am sure they will eventually make them with enough demand. They look nice, unlike the fugly Nitto Mud Grappler.
