New OEM drivers side handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by shankyjones, Jan 4, 2023.
  1. Jan 4, 2023 at 2:59 PM
    shankyjones
    shankyjones [OP] Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    I just installed the new handle and it feels like crap! Clunky and feeling like it is about to break. Argh!!
  2. Jan 4, 2023 at 3:01 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    A pillar handle? Got any pics? Did the bolts tighten down to your satisfaction?
  3. Jan 4, 2023 at 4:12 PM
    shankyjones
    Richard
    Marina CA
    What is a 'pillar' handle? I tightened them to the 'snug' level since the bolts go into a softer steel female.
  4. Jan 4, 2023 at 6:37 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah I bought an oem one from a dealer.....driver front......and it feels crunchy brandnew out of the box.........
    kinda sucks lemons for a $60 part.........
    After that I'd tell everybody to buy the dorman ones......
    every time I'd place an order for something with amozon....I check for open box dorman ones they have all the time........usually $7 or $8......to tag on the end of an order to get the free ship.......
    ......I've scored a left and a right over the last year......
  5. Jan 4, 2023 at 7:44 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Dorman handles and chock them filled w white lithium grease
    Xbeaus likes this.
  6. Jan 4, 2023 at 8:41 PM
    shankyjones
    Richard
    Marina CA
    Silver, do you have a link for the Dorman handle? I want to make sure I get the right part
  7. Jan 4, 2023 at 8:45 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Did you clean the mechanism inside the door?
    Gummed up mech will make any handle feel bad and fail prematurely.
    Bivouac and Kiloyard like this.
  8. Jan 4, 2023 at 9:18 PM
    Sebz13
    Shane
    Maui Hawaii
    look on Amazon and find the ones made by doorman or check rock auto
  9. Jan 4, 2023 at 9:33 PM
    O'Silver_Taco
    MD
  10. Jan 5, 2023 at 6:14 AM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    A-pillar grab handle. Your title didn't specify that you were referring to the door handle. Please ignore.
  11. Jan 5, 2023 at 7:00 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I replaced mine with a rockauto unit because it was really cold and my old one just snapped off. Twice. So I used some Houdini lock cylinder spray. Been perfect ever since. I sprayed it in the key hole and took my door card off and sprayed it on all the linkage. I think they get sand and dirt up in there and it makes it easier to bind up.
    Bivouac likes this.
  12. Jan 5, 2023 at 8:32 PM
    O'Silver_Taco
    MD
    Here's the open box ones.....they were still in their factory sealed bags...
  13. Jan 6, 2023 at 1:39 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    Besides greasing the arms, check to see if any of the arm tabs inside the door are bent. Just went through this. Door handle broke. Replaced with OEM, didn't feel great. Pulled back apart and realized arm was bent.
    Reference this video: https://www.youtube.com/watch?v=OzEqA9Rk0XA
    Event if you are not having that issue, it got my handle back to feeling new
  14. Jan 6, 2023 at 4:58 PM
    shankyjones
    Richard
    Marina CA
    My new OEM one lifts quite high until it opens. I will take apart this weekend and clean/lube all mechanical parts to see if that helps
