New owner of a 2021 Tacoma TRD off-road - issue with PTR20-35110-BK (oem TRD pro 4Runner wheels)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jayhat, Feb 3, 2021.
  1. Feb 19, 2021 at 3:23 PM
    #41
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    That’s something I accept for sure. I bought my TRD wheels from you guys (assuming you represent Olathe?) and they arrived here in Canada no problem.
  2. Feb 20, 2021 at 6:29 AM
    #42
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    No sorry didnt mean to imply Im with Olathe. Im just a parts slinger for a dealership, unrelated.
    327 and Stocklocker[QUOTED] like this.
  3. Mar 8, 2021 at 11:05 AM
    #43
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    Can I use the stock lugs from a TRD sport on these wheels?
  4. Mar 8, 2021 at 1:01 PM
    #44
    Jayhat
    Jayhat [OP] Well-Known Member
    thedismaltrade and tacomatm21 like this.
  5. Mar 8, 2021 at 1:53 PM
    #45
    initfortheshorthaul
    initfortheshorthaul Well-Known Member
    CA
    2018 TRD OR
    Even with a rusted center hub the wheel should fit in with some wiggle. Sounds like bad qc on the rims.
  6. Mar 8, 2021 at 2:30 PM
    #46
    Jayhat
    Yep it was a bad set. Ordered another set and it was ok.
  7. Mar 8, 2021 at 3:11 PM
    #47
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    Kinda funny that it was 2 wheels though right? They are individual wheels, not a set. You just happened to buy 4 and 50% of them didnt fit. Weird. Glad it worked out op! :D
  8. Mar 8, 2021 at 3:12 PM
    #48
    Jayhat
    They eventually tried all 4. I suspect the issue was with an entire batch toyota had made. No way I will ever know though.
  9. Nov 14, 2021 at 7:05 AM
    #49
    Soundguy89
    Soundguy89 Member
    I just had a set of OEM TRD Pro Wheels and took them to be installed on my 2017 4Runner Limited. None of them fit according to my tire installer. He has ordered a set of 1/4" spacers to solve the problem. Frustrating that OEM Parts don't fit.
  10. Nov 14, 2021 at 9:11 AM
    #50
    Surfermonkey
    Surfermonkey Active Member
    2019 c. Blue Tacoma 4x4
    Yeah, I would not use a spacer to facilitate mounting of a broken or incorrectly spec'd thing
  11. Nov 14, 2021 at 10:33 AM
    #51
    Soundguy89
    Soundguy89 Member
    I’m ok with it if the installer oks. The issue is such that it’s a couple millimeters short of going flush against the wheel mount. 1/4” spacer solves that issue with only difference being the wheel barely pushed out. Is there another downside I’m missing or a different option? New wheels already mounted on the tires
  12. Nov 15, 2021 at 6:31 PM
    #52
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    As long as the wheels center on the hub you should be fine. If the spacer pushes the wheels to where only the chamfer or nothing at all centers the wheel it will be a problem. These wheels are not lug-centric.
    Jeff
