New owner with Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by holen1, Mar 1, 2010.
  1. Mar 1, 2010 at 6:36 AM
    holen1
    holen1 [OP] Member
    Philadelphia, Pa
    2004 Tacoma
    Bilstein 5100
    Hi all,
    I am a new owner of a 2004 Toyota Tacoma /double cab with 45k miles. I've never owned a truck before so there are some questions I have for you guys.
    First is the ride quality, not sure if i have to replace the shocks, but when I hit a bump or a pot hole....it feels like the shocks are dead. Like I said, I have never own a truck, so I really don't know if this is normal.
    Second, when ever I come to a stop, it feels like a bump or jerk after the before the truck stops completely. I didn't notice it when I test drove the truck. Now that I have been driving it for two days, it's annoying the hell out me. Please help.
  2. Mar 1, 2010 at 6:48 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    the soft spring rate up front is the main reason i swiched to an aftermarket coilover. if you move up to a 650# spring it will take care of the squishy front end.
    the "clunk" you're feeling in the rear is likely due to axle wrap. ...i replaced my rear leaf packs with a custom pack from Alcan. ..haven't noticed any axle wrap since.
    in my opinion, to make these trucks ride the way i think they are supposed to ride, replacing the stock suspension is the only way to go. ..i was very dissapointed with it in stock form.
  3. Mar 1, 2010 at 6:55 AM
    holen1
    holen1 [OP] Member
    Philadelphia, Pa
    2004 Tacoma
    Bilstein 5100
    Will this address the bump when coming to a stop or the suspension issue. Also can you recommend some good brand of springs.
  4. Mar 1, 2010 at 8:09 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    yes. ..that will minimize the bump you're feeling when you come to a stop.
    i would suggest going to and browsing around.
    most people go with either deaver or alcan rear springs. ..both make excellent springs. if you're buying off the shelf (not getting a custom pack) i prefer the alcan springs as they arch the drivers side spring a little more to account for the extra weight on that side. i don't think deaver does that on their off-the-shelf springs. this was very important to me as i HATE the taco lean. ...toyota really dropped the ball by putting the battery, gas tank, and driver all on the same side.:cool:
    here's another option for addressing axle wrap ....
    http://www.budbuilt.com/new/traction_bars.html
  5. Mar 1, 2010 at 9:59 AM
    BurritoJimmyFan
    BurritoJimmyFan Well-Known Member
    Frisco, TX
    04 Ext Cab TRD
    Gray Wire Mod, DRL Mod, Deckplate Mod
    congrats on the purchase. That's pretty low miles for an 04. I think all you need is new shocks. It will greatly improve the ride. IMO, the factory shocks are junk. I've had good experiences with the Bilstein heavy duty and the 5100.
  6. Mar 1, 2010 at 10:16 AM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    yep most likely the struts but before your spend the money make sure to check your ball joints. very common on out style taco. just replaced mine recently, they where destroyed. the uppers that is. good buy buy though, work out the bugs and you got a great truck for a long time to come:) welcome to tw!
  7. Mar 1, 2010 at 11:56 AM
    holen1
    holen1 [OP] Member
    Philadelphia, Pa
    2004 Tacoma
    Bilstein 5100
    Thanks all for the reply,
    After spend more time reading the forums, I might just get a whole new suspension kit.
    I was thinking of going with the OME kit from toyotec.com. It's a pretty popular brand from some of the members here.
  8. Mar 1, 2010 at 4:29 PM
    747 function > form
    1st Gen.
    Add-a-leaf on the rear and lube your truck...save yourself some $. RE the budbuilt option...not worth it IMO...I did it and I don't regret it bc it works, but I can think of other stuff I'd rather spend my $ on. Just my 2 cents.
  9. Mar 1, 2010 at 4:36 PM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    I also just bought my 1st gen
    I have the same issue with the jerking. its axle wrap. check your leaf springs. if they are flat like pancakes, this is your problem. I know mine are flat. the best route is a new leaf pack from wheeleroffroad.
    do not do an AAL. it will ride like shit. that is the cheaper way, but spend the extra money and do it right. go with a new leaf pack
  10. Mar 1, 2010 at 5:16 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    x2 the stock shocks are worthless.
  11. Mar 2, 2010 at 6:53 AM
    holen1
    holen1 [OP] Member
    Philadelphia, Pa
    2004 Tacoma
    Bilstein 5100
    Yea the little jerk is the most annoying thing about the truck. Thanks, I will look at this option also.
  12. May 26, 2010 at 11:19 AM
    shift96
    shift96 Well-Known Member
    The stock shocks are bilsteins. Far from worthless.....
  13. May 26, 2010 at 11:39 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    These rear leaf packs will change the height of the truck. What if the OP wants to stay at stock height with new packs?
  14. May 26, 2010 at 11:46 AM
    shift96
    Well here's a question: Is axle wrap so bad? I have been driving my truck for 6 years and put 120K on it with said "Axle wrap" and no problems whatsoever. The clunk doesn't bother me, certainly doesn;t bother me enough to drop $500.00 to get rid of it
  15. May 26, 2010 at 11:47 AM
    Madjik_Man
    Colorado Front Range
    I have a '98 with 130K on it and have never experienced "axle wrap." I have no idea what it is
  16. May 26, 2010 at 11:48 AM
    shift96
    It's no big deal. Slight clunk every now and then. If it was a big deal I doubt I could have driven it for 6 years and 120K
  17. May 26, 2010 at 12:44 PM
    scocar
    scocar Patron of the Farts
    The other extremeley cheap thing you can do to help reduce the annoying thunk is make sure the slip yoke on the rear drive shaft is properly lubed up. If it is dry, the shaft can bind up a bit when the axle twists when braking to a stop or when pulling away in first. Chances are, the whole driveline is due for a good greasing. I think it is recommended evey 15K. Relatively easy DIY if you have the grease guns, grease, and don't mind rolling around under your truck. This is a great way to familiarize yourself with it and inspect it.
  18. May 26, 2010 at 1:32 PM
    mlittle
    mlittle T O Y O T A
    Michael
    Fort Sill, OK
    2014 Toyota Tundra Crew Max 4x4
    Welcome holen1. Looks like you will have your hands full soon with upgrades - time for a mod day in Philly.
    Let me know if you need help. I have a feeling that I will need to replace my suspension shortly. I noticed that my rear leaf springs look rather flat. I will submit pics and let those with more knowledge let me know.
  19. May 26, 2010 at 2:52 PM
    scocar
    If you guys want some good reading and more links about spring stuff (with pics), check out our recent Wheeler's group buy (maybe you have already seen this). It is now closed, but that doesn't mean you couldn't pull together another one if YotaDan is up for it...:D
    http://www.tacomaworld.com/forum/gr...heelers-offroad-1st-gen-leaf-replacement.html
    From what I have discovered, it is pretty freaking hard to find any leaf springs that are better/stronger but don't lift at least a little. I didn't want to lift, I just wanted a vehicle with safe, comfortable, and predictable handling--something the stock suspension with 100K miles can not deliver.
  20. May 26, 2010 at 3:07 PM
    4wdExplorer
    Orange County, CA
    So what leaf springs did you end up buying?
