New Pioneer DMH-WC6600NEX flush mount install
Discussion in 'Audio & Video' started by PreRunnerSeth, May 27, 2020.
  1. Jun 12, 2020 at 5:13 AM
    #161
    PreRunnerSeth
    PreRunnerSeth [OP] Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    If you have touch buttons on your factory HU it's a premium one. If you have physical buttons it's a standard one.
    Ch78[QUOTED] likes this.
  2. Jun 12, 2020 at 5:22 AM
    #162
    PreRunnerSeth
    Apex, NC
    I have a spare premium bezel if anyone needs it. No trim on it so you will have to take the trim off your other one.
  3. Jun 12, 2020 at 7:54 AM
    #163
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    @PreRunnerSeth I sent you a PM about purchasing you bezel. Thanks
  4. Jun 12, 2020 at 9:17 AM
    #164
    B.Peak
    B.Peak Well-Known Member
    Brian
    SWFL
    '19 Tacoma TRD Sport 4X4
    '19 Tacoma TRD Sport 4X4, Premium and Technology Packages OME-888 Coils w/ OME-90021-P Nitrocharger Sport Shocks- softer valving ToyTec .5" Top Spacer OME-EL095R-P Rear Leaf Pack w/ OME-60091-P Nitrocharger Sport Shocks Eibach 1" Lift Block OME Upper Control Arms OME Driveshaft Carrier Bearing Drop Kit ToyTec 1" Diff Drop ECGS Clamshell Bushing 18X9 Enkei RPT-1, 0 Offset on LT305/65R18 TOYO Open Country M/T 2020 OEM Limited Grill 2020 OEM Limited Fog Light Bezels MESO Stage 1 Total Tail Light Kit All Interior and Exterior lights replaced with Diode Dynamics LEDs TRD Cat Back Exhaust Passenger Door Smart Key Mod
    I'm just starting my research on this. Did you need anything to connect directly into your factory amp? What about sound quality, back up camera quality?
  5. Jun 12, 2020 at 10:18 AM
    #165
    PreRunnerSeth
    Apex, NC
    You need the maestro stuff and adapter harnesses. As posted up above. Sounds much better and the camera looks better IMHO. It's still the stock camera and is not the highest res thing.
  6. Jun 12, 2020 at 10:50 AM
    #166
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
  7. Jun 12, 2020 at 11:05 AM
    #167
    GPH36
    GPH36 Well-Known Member
    2019 Black TRD Pro
    Dumb question. How hard was it to get the mic to the factory location? I’ve never had to mess with a headliner before, and am curious as to what it takes to route it there. Thanks!
  8. Jun 12, 2020 at 11:13 AM
    #168
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Pedro2598 likes this.
  9. Jun 12, 2020 at 11:17 AM
    #169
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Simple. Pull the over head console down, disconnect the factory mic, pop it out, run your new mic wire up the driver side pillar then over to the center. Once you get the mic to the center pull the headliner down just enough to push the mic through. Use double sided tape to secure it in the place of the factory mic, put the console back on. One it’s done go back and push the wire under the headliner then the molding (or whatever it’s called) on the pillar. Secure it under the dash with zip ties. Done
    GPH36 likes this.
  10. Jun 12, 2020 at 11:17 AM
    #170
    GPH36
    2019 Black TRD Pro
    Thanks! From the thread you posted, I take it that the Pioneer mic will not fit in the factory stock mic location?
  11. Jun 12, 2020 at 11:24 AM
    #171
    Ch78
    Ch78 GBO!
    Tomball, TX
    It will, just need to use double sided tape.
    svermilyea and GPH36[QUOTED] like this.
  12. Jun 12, 2020 at 11:26 AM
    #172
    GPH36
    2019 Black TRD Pro
    Awesome. Thanks!
  13. Jun 12, 2020 at 1:46 PM
    #173
    Arisian
    Arisian Well-Known Member
    2019 Gray Tacom SR5
    none yet!
    Im considering the 10-inch, DMH WT8600NEX just so I don't have to mess w/ the standard bezel that I have on my SR5 w/o premium audio.
    I don't personally mind a floating look if it's covering the bezel. I do like the look of the 9 inch, but my router is a piece of garbage and Im 60% sure I would need to purchase a new mount for my table saw - seems like a solid 5 hours, and a new router (not a bad thing?) - The premium bezel might be fine, but that's another $300 purchase, correct?
    Unsure yet. Anyone have thoughts?
  14. Jun 12, 2020 at 2:09 PM
    #174
    PreRunnerSeth
    Apex, NC
    if you keep an eye on ebay the premium bezels pop up on a semi regular basis. dont worry if the color trim part is scratched. you get better deals on the scratched ones and you can move the colored trim over from your other bezel. the 6600 is by far the cleanest looking main stream aftermarket HU. the 8600 is also quite a bit more money just to gain 1 inch.
  15. Jun 12, 2020 at 2:15 PM
    #175
    Arisian
    2019 Gray Tacom SR5
    none yet!
    I think the take away here is that I shouldn't be worried about screwing up a bezel :)
  16. Jun 12, 2020 at 2:30 PM
    #176
    GPH36
    2019 Black TRD Pro
    How difficult was the installation? I’ve only ever attempted to install an android unit (Joying/Dasaita) which was pretty straightforward.
    Is this installation much more involved?
  17. Jun 12, 2020 at 5:16 PM
    #177
    CRogersism
    CRogersism Well-Known Member
    6600's sold out on crutchfield. Guess I'll have to wait. Those Meso Customs trim blackout pieces, is the MGM close to the rest of the interior trims pieces (Door Panel/Dash) or completely different grey?
  18. Jun 12, 2020 at 6:05 PM
    #178
    CoAlpha
    CoAlpha Well-Known Member
  19. Jun 12, 2020 at 6:12 PM
    #179
    Ch78
    Ch78 GBO!
    Tomball, TX
  20. Jun 12, 2020 at 8:00 PM
    #180
    dwillhere1
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    Can u send me the link u used for this wallpaper? Did u just use the avdata app to load it to the screen from your phone?
