New power door actuator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Monkeysuncle, May 30, 2012.
  1. May 30, 2012 at 11:15 AM
    Monkeysuncle
    Monkeysuncle [OP] My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    My pass door will not lock or unlock with either the key, door button or key fob, so I called my local dealership and they want $312.00 for the part, :eek:. Bad thing is I have the door panel off and if I even have someone in the truck and need to do an emergency evacuation, the f**ng door can't even be opened from the inside. Is there any other route I can take to use afrermarket actuator or just carry around a brick to break the window, you know, incase of an emergency?
  2. May 30, 2012 at 12:01 PM
    Madjik_Man
    Colorado Front Range
    My passenger side door lock actuator hasn't worked in 8 years.
    Can't you just pull the lock up manually and then open the door? :confused:
    A TW member pulled a door lock actuator off an 85 pick up for me. Haven't gotten around to seeing if it works or not but it was only $5
