New purchase inspection
Discussion in '1st Gen. Tacomas (1995-2004)' started by NM PreRunner, Aug 4, 2022.
  1. Aug 4, 2022 at 8:33 AM
    NM PreRunner
    NM PreRunner [OP] New Member
    2004 Tacoma PreRunner
    I just got a crazy good deal on a 2004 PreRunner. This is going to be my daughter’s first vehicle. I know the newer Taco’s and 4Runners very well, but I’m not as familiar with these 1st gens. What are the common maintenance items or “problems areas” on these trucks. I’m going to go over it too to bottom, but looking for insight in to any specific issues you all may have seen. Thanks!
  2. Aug 4, 2022 at 8:50 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Check out the 1st generation Buyers Guide in the Sticky thread section.
    Always good to let us know where the Truck has lived.Knowing what drive train also helps.
    Once you inspect the frame your dealing with a normal 18 year old vehicle always going to be neglected areas
    Taco critter likes this.
  3. Aug 5, 2022 at 5:43 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Welcome to TW
    Make sure the rear shocks aren't mounted like this:
    CrustyTaco, noodles93 and ztwatson like this.
  4. Aug 5, 2022 at 11:21 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Oh that's fineee just don't worry about it
  5. Aug 5, 2022 at 11:51 AM
    Bivouac
    Looks fine to me Till the Shock is compressed all the way and Punches through the bed.
    Better then banging around making noise.
  6. Aug 5, 2022 at 7:46 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah something went wrong with the corrosion proofing on the these and the FJ's....
    So you got to go low....and carefully check it out......
    Make sure u dont have an oil burner- pull a plug(s), no milkshake oil, and no continuous white smoke out of exhaust(head gasket failure).....
    If any thing is brand spankin new, including fluids.....be suspecious.....
  7. Aug 7, 2022 at 7:10 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    If you buy it, do the lower ball joints regardless of how the inspection rates them. It's very important.
