New Rear Leaf TSB T-SB-0305-08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Oct 3, 2008.
  1. Mar 1, 2009 at 4:48 PM
    #201
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Does anyone know if the TSB increases the payload capability beyond the 1350 lbs?
  2. Mar 1, 2009 at 6:00 PM
    #202
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
  3. Mar 2, 2009 at 4:47 AM
    #203
    grivera
    Hanover, MD
    That's wierd, a 2009 Tacoma has a higher payload than a 2008 Tundra??
  4. Mar 2, 2009 at 8:06 AM
    #204
    DLPerry432la
    DLPerry432la 07La
    Dave
    Downtown LA
    07 Pre-Runner SR-5 TRD Off Road 2 X 4
    All Eligible Factory TSB's performed. Sway Away Race Runner Adjustable Front Coil-Overs, Bilstein 5100's in the rear with Deaver 3703-K33 Leafs, Camburg UCA's and 4" Drop Spindles, Pro-Comp Extreme 285/75/16 Tires 33", on Moto Metal Wheels,AIRAID Cool Air Intake, Pioneer 6100 AM/FM/CD/Satellite Radio, HID Headlamps Hi-/Lo
    I think the TSB was already completed on all new trucks. If you have 3-leafs and a helper spring, the correction has already been made.. If you need more support you can install an AAL.
  5. Mar 2, 2009 at 8:29 AM
    #205
    DLPerry432la
    DLPerry432la 07La
    Dave
    Downtown LA
    OK ... I should have read the whole thread... Derr.... I had the TSB completed a week ago and added a strut extension on the front end to level out the truck. This weekend I was anticipating good results from the new rear leaf springs. I loaded up (2) 235 lb dirt bikes in the back with a medium cooler and an aluminum loading ramp into the truck bed. Added a small tool bag and (2) moto-x gear bags into the back seat. Then before my son and I got into the truck I took a look at the leaf springs.. They were inverted approximately 1½-2". Better than before the TSB but I was, to say the least, a bit disappointed.
    There is NO-WAY that even with the new leaf pack that my Tacoma could possibly support a payload (In the bed) even close to 1,350 pounds. I would be sitting on the frame stops the entire ride.
    As it is now, with the (2) dirt bikes in the back with the weight evenly distributed over the rear wheels (approximately 475 lbs) I felt the suspension bottom out at least 2 times on the freeway. Not as hard or nearly as bad as before, but it still hit.
    I would assume the payload capacity would have to include all passengers and everything else loaded in the cab and in the bed.
  6. Mar 2, 2009 at 8:45 AM
    #206
    atea
    atea Member
    Rhode Island
    09 Tacoma
    grille painted to match body color (black sand pearl), bed mat, intermittent wipers installed, 14" shorty antenna.
    How would I know if TSB was completed on my 2009? I'm not sure what a helper spring is and/or if I have one? Not sure also what an AAL is? Is it possible that based on the ID numbers on my rear springs that they are OK in my vehicle or is it that 3-leaf springs are just not adequate period? The numbers on my rear springs are: left rear = 48220-04160 and right rear= 48210-04370. F.W.I.W., I did call Toyota Customer Service today and got case #. I checked with my local dealer where I purchased truck and was told that they could not do the TSB due to year and that it applied only to 4WD vehicles. They said they would check with area rep--can't imagine that will change anything.
  7. Mar 2, 2009 at 10:26 AM
    #207
    DLPerry432la
    DLPerry432la 07La
    Dave
    Downtown LA
    If the TSB was already corrected by the factory, you would have a stack of leaf springs (3) curved and (1) flat (Helper)
    The TSB applies to both 2WD and 4WD vehicles but has not been updated to include 2009 trucks as of yet.. If your truck has the old 2-leaf, 1-helper spring then I would assume that eventually they will update the TSB to include your year model.
  8. Mar 2, 2009 at 2:58 PM
    #208
    Jpf8653
    Jpf8653 Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    If i were to load a Honda Recon in my tacoma might that show me the weakness of the rear springs or would i need to go heavier to feel the issues some are experiencing?
  9. Mar 2, 2009 at 3:06 PM
    #209
    DLPerry432la
    DLPerry432la 07La
    Dave
    Downtown LA
    I'd load it up and take a drive... See what happens when you drive up a driveway (slow... but not too slow) and on normal roads with little dips and stuff. Also, once loaded, take a look at the springs and how much clearance is left between the freame stop and the top of the springs
  10. Mar 2, 2009 at 3:10 PM
    #210
    Jpf8653
    Justin
    Baton Rouge,LA
    Bout to go take a drive with it. The clerance is a llittle less than 2 inches. I have a revtech 3" lift with blocks in the back. Would this chnage my clearance?
  11. Mar 2, 2009 at 3:21 PM
    #211
    DLPerry432la
    DLPerry432la 07La
    Dave
    Downtown LA
    It certainly won't change the spring rate.. They'll still be inverted when loaded..
  12. Mar 2, 2009 at 4:26 PM
    #212
    hoosiertaco
    hoosiertaco Well-Known Member
    Yet again another example of a dealerships inept ability to give the truth.
    The real reason they can't do it for you is the TSB does not cover reg cab.Sorry.:((and the '09s aren't on the TSB yet) They are wrong about only for 4wd too. The TSB states that it is for Prerunner, which are always 2x4's.
  13. Mar 3, 2009 at 10:48 AM
    #213
    CWOF
    CWOF siemprelisto
    '09 Tacoma DC TRD Off-Road w/towing pkg
    Prodigy II Brake Control, Rear Leaf Spring TSB, Extra D-ring Tie downs, All-Weather Mats, K&N 33-2281, Mobil1
    The rear leaf spring TSB on my '09 DC TRD Off-Road was completed by the dealership today, in less than five hours. The ride is firmer and it appears to have corrected the infamous Tacoma "left lean."
    I read through most of the TSB threads for background and advice then called the Toyota 1-880- number listed in other threads before I went to the dealership. I explained the "harsh ride" I experienced everytime I loaded more than 600 lbs. in the truck bed. The representative opened a case, gave me the case number, and sent an email to the dealership. No hassles, very professional.
    The next morning I received a call from the dealer's service department stating they had received the case and had ordered the parts. The parts arrived yesterday, I brought my Taco in, they gave me a free rental (white Corolla-I was able to partially keep my man-card), called me five hours later to tell me the work was complete. Everything went seemless!
    :burnrubber:
    Rick Hendrick Toyota ROCKS!
  14. Mar 3, 2009 at 11:02 AM
    #214
    Bolo
    Bolo Well-Known Member
    San Diego
    2007 TRD Offroad
    Billet grill, nerf bars, TSB, Bilstein 5100s, Pioneer deck, Access Literider, shorty antenna
    You got lucky with the corolla. I got stuck with a solara convertible. I thought about putting the top down since I've never been in a convertible, but I decided against it.
    Btw, on your service printout given to you, did it list that an alignment was performed? the service adviser swore it was performed within spec, but it was not listed on the sheet...
  15. Mar 3, 2009 at 11:19 AM
    #215
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    I followed the same procedure as CWOF. I'm waiting to hear back from my dealer right now. Will let you know what happens!
  16. Mar 3, 2009 at 1:30 PM
    #216
    CWOF
    CWOF siemprelisto
    The Corolla was, well, appreciated and returned quickly. I'll have to check the service ticket, but I was told the alignment was checked.
  17. Mar 3, 2009 at 6:05 PM
    #217
    jmslangdon3
    jmslangdon3 Member
    Toyota told me today that it is just 4 wheel drives and 4 wheel drives with the TRD package is this true. Cause the way I understand it is that it doesnt matter wheather it is 4 wheeldrive. Anyone know.
  18. Mar 3, 2009 at 6:57 PM
    #218
    hoosiertaco
    Straight from the TSB on the first post. It is for both 2 and 4 wheel drive. TRD or not doesn't matter.
    Applicability
    YEAR(S) MODEL(S) ADDITIONAL INFORMATION
    2005 – 2008 Tacoma Body Type(s): Access CabDouble Cab,
  19. Mar 3, 2009 at 6:59 PM
    #219
    jmslangdon3
    jmslangdon3 Member
    Thats what I thought. thank you
  20. Mar 4, 2009 at 3:56 AM
    #220
    grivera
    Hanover, MD
    Actually, 4wd and Prerunner, since Prerunners have the 4wd suspension.
