New Recall~drive shaft replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by volks71folk, Dec 6, 2017.
  1. May 3, 2019 at 8:34 AM
    #381
    Hillbilly Willy
    Hillbilly Willy Well-Known Member
    Central PA
    2005 blue Tacoma DCSB TRD Sport
    Didn’t TSB ZH2 end on April 30?
    Reinhardtius[QUOTED] likes this.
  2. May 3, 2019 at 8:54 AM
    #382
    Reinhardtius
    Reinhardtius Well-Known Member
    07 Base 2.7L 5SP
    Negative, secondary is still in place.
  3. May 3, 2019 at 5:31 PM
    #383
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Save yourself the big Toyota circle jerk headache and just buy a 1 piece driveshaft. Then put some real springs in and dump the Toyota sag and spring wrap that made the crappy 2 piece driveshaft angles wrong. I gave up due to the lack of dealer or factory help years ago. Even wrote letters and was that a big waste of time as they want written documentation that no one has so I could picture their legal guys just laughing their asses off as customers were trying to comply ha ha! Toyota knows the problems but their bottom line profit wins out as legal covers their asses and wears the customer down - gotta love the system! After that realization I replaced the driveshaft and springs myself with better aftermarket and my Tacoma finally worked correctly - and my blood pressure sure dropped.
    BassAckwards and Hillbilly Willy like this.
  4. May 6, 2019 at 1:39 PM
    #384
    Reinhardtius
    07 Base 2.7L 5SP
    If this suggestion was oriented toward me, I do not think I have a two piece drive shaft. My truck is a 5 foot bed regular cab, and does not have a carrier bearing or any of that silly stuff.
  5. May 23, 2019 at 11:35 AM
    #385
    hawesb8719
    hawesb8719 New Member
    Hi All, thought I would share my recent experience with Toyota on the U-Joint issue. Received the notice almost a year ago and wasn't experiencing issues at the time so I didn't want to pay the dealership for a diagnostic. About a month ago I began to experience the vibration in the driveline and immediately called my dealership to schedule a U-Joint/Drive Shaft inspection. I called on April 29th and the earliest availability the dealership had was on May 10th. Went into the dealership on the 10th and sure enough I had a bad U-Joint; unfortunately the warranty enhancement expired on April 30th and they could not perform the work under the warranty enhancement program. I explained how I called prior to the expiration date but the dealerships hands were 'tied'; so I called Toyota Headquarters. The first rep was very rude so I called back and spoke to a rep named Paige; she was very friendly and sounded like she was doing all she could to check into the issue. After two weeks I have found out that Toyota will not do anything to help resolve this issue.
    Any suggestions from anyone on how to get Toyota or the dealership to acknowledge the warranty enhancement program would be appreciated!!
  6. May 24, 2019 at 6:03 AM
    #386
    Reinhardtius
    07 Base 2.7L 5SP
    I left my truck unannounced in the parking lot citing safety concerns AS SOON AS I experienced it. That way they diagnose on the spot and you don’t get pushed out by a busy schedule.
  7. May 24, 2019 at 6:22 AM
    #387
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Just do it (Double cardan joint aft CB) and be done.
  8. May 24, 2019 at 7:58 AM
    #388
    mperl
    mperl Well-Known Member
    Texas
    Impulse Red 2006 PreRunner SR5 TRD Quad Cab
    Man, I wish someone had brought this up when I asked about the vibrating noise I was hearing prior. Toyota dealer now says I am too late for Toyota to pay for it.
  9. May 24, 2019 at 7:59 AM
    #389
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Really? I had about 150k and 8 years on my truck and they did the u-joint at no cost to me
  10. May 24, 2019 at 8:04 AM
    #390
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    I so want to. How did you do it? Custom? What did it run ya?
  11. May 24, 2019 at 2:03 PM
    #391
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Customized stock driveshaft. Front half is same, smaller 1310 u-joint (stock u-joints are 1330) double cardan joint (with Ford Ranger center bearing) and the rear driveshaft was flipped 180* and shortened some, to make room for the double cardan joint. About $500 from a local shop.
    EDIT: Found an old post with part numbers and a basic break down;
    Starting at the front and working towards the diff:
    T-Case > Front Shaft > Center Bearing > 2-4-4341 Spicer spline end yoke > Spicer 1310 u-joint > 211355X Spicer centering yoke > 2-26-497 Spicer double cardan center > Spicer 1310 u-joint > 2-28-2977X Spicer Tube Yoke >
    NEAPCO 5368 - 3" to 3.5" adapter to fit 2-28-2977X to flipped and shortened rear driveshaft > Rear Driveshaft > Diff
    Lots of good info in this thread: https://www.tacomaworld.com/threads/single-and-two-piece-driveshaft-vibes-be-gone.475797/page-29
    jross20[QUOTED] likes this.
  12. May 25, 2019 at 10:50 AM
    #392
    jross20
    Georgia
    Thanks man, after I purchase my 3rd gen 4runner I'll look into this!
    jmanscotch[QUOTED] likes this.
  13. Aug 12, 2019 at 7:04 AM
    #393
    Fishbear11
    Fishbear11 Well-Known Member
    Can somebody explain to me what secondary coverage means. I got the letter a while ago, but had no vibration. Seems that I ran out of time in the primary coverage. Noticed on my way to work last night that I’m getting a vibration when accelerating. When I let my foot off the gas it’s not there. Seems pretty consistent with the problem people have had and covered. I also got my truck back for frame replacement a month ago so I don’t know if that has anything to do with it.
    dbole007 likes this.
  14. Feb 12, 2020 at 9:23 AM
    #394
    lynyrd3
    Bill
    East Central Upstate NY
    12 years from the trucks in service date . The day it was purchased and left the dealer .
  15. Mar 16, 2020 at 6:48 AM
    #395
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    So, how did it turn out? Did Toyota fix it? Was there a charge?
