New shocks for stock ride height, smooth ride, and carry motorcycle
Discussion in 'Suspension' started by kogary, Feb 4, 2012.
  1. Feb 4, 2012 at 11:40 AM
    kogary
    kogary [OP] Well-Known Member
    Denver
    2005 Indigo Ink AC, V6, auto, 4x4
    Heated drivers seat, JVC HU, Sound Ordinance compact 8" sub under passenger seat, Morimoto projectors/D25 HIDs, LED lit cupholder mod
    Hi guys,
    I've been doing some research this past month on replacing my stock suspension components. I saw a thread in the DownSouth Motorsports section with a good deal on 5100's so I figured I'd run my situation by you guys to get any additional input before submitting my order with DownSouth (I'm all for supporting our local vendors!!).
    I've found that 99% of the threads I've come across are for people wanting to lift their trucks in some fashion (e.g., small lift, big lift, coilovers, blocks, etc., etc.), but I haven't really come across many threads that address stock ride height upgrades (w/ increased load capacity) that address or are similar to my particular situation.
    Truck Background:
    - 2005 Access Cab SR5 4X4
    - ~55,000 miles on the truck
    - All original suspension parts
    - Original 3 leaf spring pack in the rear (no TSB)
    - The original 3 leaf spring pack is no longer arched, rather it sits neutral with a slight 'W' look to it
    - Stock size SR5 wheels/tires and staying that way
    ** I would like to keep the stock ride height
    This is my daily driver and I commute about 90% highway miles, so a smooth ride over a 1 hour long drive is very important to me.
    I don't off-road my truck (nor do I plan to start doing so). At most, I drive through the mountains and go camping, but nowhere that requires off-roading (mainly bumpy dirt service roads).
    I DO however, load my motorcycle in the bed of the truck to take it to the racetrack about once a month during the summer. I've noticed that when fully loaded (~500 lbs with gear), the rear sags slightly.
    I want to be able to continue taking my bike to the track, but I really don't want to compromise ride quality seeing as 99% of my driving is daily commuting.
    After a bit of researching I've come to the following conclusion for what might suite my needs:
    - Bilstein 5100's (all 4 shocks),
    - Custom 4 leaf spring pack that maintains stock ride height
    Do you think my stock SR5 coil springs suffice for this (again, no lift, stock ride height)? I'd have a hard time believing the coil springs themselves are shot with only 55k on them, but I could be wrong...
    Do you think this would be a good setup for what I use the truck for? If not, can you give me some other recommendations (I'm open to other brands too)?
    I'd like to get this ordered and installed (I'll be installing myself) sooner rather than later, seeing as the racetrack has 1/2 price specials during the winter and I'm itching to take the bike out!
    Thanks for the advice guys!
    - Gary :)
  2. Feb 4, 2012 at 11:43 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    Sounds good to me for your setup! I'd do this and call it a day.
  3. Feb 4, 2012 at 11:48 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I thought the TSB springs would fix the sagging. out of warranty now?
  4. Feb 4, 2012 at 11:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The custom leaf pack would be a great idea but also pricey. Have you thought about something like airbags to suppliment your stock leaf springs? Your front coils are fine for stock ride height. It's the leaf springs that suck.
  5. Feb 4, 2012 at 12:06 PM
    Pugga
    Massachusetts
    x2 what Brock said, he's way out of warranty. Plus, the TSB leaf springs still aren't great. A custom leaf pack would be a HUGE improvement over the TSB leaf pack.
