NEW! SS3 LED Pods for Toyota Tacomas! | Diode Dynamics
Discussion in 'Diode Dynamics' started by Diode Dynamics, Dec 3, 2019.
  1. Feb 4, 2021 at 2:12 PM
    #261
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Like so?
  2. Feb 4, 2021 at 3:03 PM
    #262
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Yes but the actual light output from behind the steering wheel
  3. Feb 4, 2021 at 3:05 PM
    #263
    memario1214
    Colton
    Missoula, MT
    Oh! No haven’t seen it yet. You can rest assured that I’ll capture it once I get my mitts on them though.
    Maybe @ptothegdotcom can snap some too! I know he has a set on its way... :cool:
    ptothegdotcom likes this.
  4. Feb 4, 2021 at 3:05 PM
    #264
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
  5. Feb 4, 2021 at 3:18 PM
    #265
    ptothegdotcom
    ptothegdotcom Well-Known Member
    P
    SOCAL
    2020 TRD OR PREM DCSB
    I will post a pic when I have them installed. Can't wait. Thanks @memario1214
    Always a high level of customer service!!! Best place to buy lights hands down.
  6. Feb 8, 2021 at 4:01 PM
    #266
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    I bought a set of 3rd gen "Pro" fogs last year. Are the Max SS3s form/fit compatible with the Pros, such that I can replace the Pros with Max-es (i.e. will they fit in the mounts you supplied with the Pros)?
    Are the Maxes still under what the original halogens were in terms of current (Amps)? Asking because I'm wondering if I would have to replace the harness.
    I will find another use for the Pros I will remove.
  7. Feb 10, 2021 at 4:15 PM
    #267
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Amber pro’s came in today
  8. Feb 10, 2021 at 4:41 PM
    #268
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Yes the chassis and mounts for the lamps are all the exact same. The Max lights only have 1 or 2 watts of power more than the Pros so it's a negligible difference. It's about 38 completed to 36 watts, still well below standard 55 watt halogen fogs. You can swap them with no changes to the mount or wiring.
    GMAN62465 likes this.
  9. Feb 12, 2021 at 5:09 AM
    #269
    mrCanoehead
    Ottawa
    Aren't there round-type and square-type though?
    I actually decided not to upgrade to Max when I found out that a set of Max lights will be over $700 Canadian dollars. I expect that price to come down when there are competing models from other vendors.
  10. Feb 12, 2021 at 8:04 AM
    #270
    memario1214
    Colton
    Missoula, MT
    I have them on sale at the moment, but exchange rates are dumb... Unless you're on the right side of them!
  11. Feb 12, 2021 at 8:36 AM
    #271
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    The different "shapes* like square, round, etc. are just faceplates that can be easily swapped. If you already have one set of lights in your fog pockets and want to re-purpose them elsewhere, just pick the faceplates you think will work best on the new lights. Then swap faceplates when they arrive.
    For example, I think I might upgrade to the Max fogs and retain my pros for cornering lights. I'll order the Max with the square bezels (they are the most compact shape). Swap bezels with the current pro fogs (which have that diagonal style faceplate) and voila. I might get the combo pattern lens for them as well.
  12. Feb 13, 2021 at 9:41 AM
    #272
    TheSupremeReader
    TheSupremeReader Well-Known Member
    Andrew
    TRD OR DCSB
    Anyone have SS3 PRO SAE Ambers in stock? I see Diode Dynamics says they are 8wks lead time!
    Matmo215 likes this.
  13. Feb 13, 2021 at 9:45 AM
    #273
    memario1214
    Colton
    Missoula, MT
  14. Feb 13, 2021 at 10:06 AM
    #274
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    That lead time isn’t accurate, they say 8 weeks but I got mine in 2.
  15. Mar 7, 2021 at 3:41 PM
    #275
    Nateurboy
    Nateurboy Well-Known Member
    Nathan
    Colorado front range
    2008 DCSB 6 spd
    Just installed mine in my 2008 and I’ve been wondering about the aim. It seems that loosening the side bolts and pushing the the fixture down as much as possible was the only way I could really adjust them. The adjustment screw didn’t seem to do much at all. Anyone else with an early 2nd gen have a similar experience and can provide some insight?
  16. Mar 11, 2021 at 6:10 AM
    #276
    dvdrdclf
    dvdrdclf Well-Known Member
    Colorado
    2010 4x4 TRD Sport AC
    SNOW
    Any idea on this?
    Also are the brackets on anyone else's able to be slightly moved up and down when pushing on them? I tightened the side bolts and that doesn't allow for movement of the pods themselves.
  17. Mar 14, 2021 at 6:49 AM
    #277
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Any update on these lenses?
  18. Mar 14, 2021 at 9:50 AM
    #278
    memario1214
    Colton
    Missoula, MT
    JUST started filming videos again today. I got a new truck and have been awaiting parts so I didn’t have a vehicle to film lol. Ditch brackets should be here this week. I expect I should be able to have a video of all of the different SS3 patterns out in a couple of weeks
  19. Mar 14, 2021 at 2:23 PM
    #279
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Sounds good
  20. Mar 18, 2021 at 6:35 AM
    #280
    SAR Taco
    SAR Taco TRD-SAR
    Bryan
    PNW
    2009 Trd-Sport DCSB 6MT Super White
    2 in. spacer lift, rear facing halogen spot lights, leer 100xr canopy, FN Fx Pro wheels in Matte Bronze. Falken Wildpeak AT3W 275/70/17 LRC. Lots of LEDs. Rear ARB air locker.
    I've had a similar experience. Have backed the adjustment screw fully in and nearly fully out without seeing much of a difference in how the pod sits. Would really like to find some help on this because my fogs sit higher than my headlights.
    I remember reading another member having figured it out for the 2nd gen and I'm trying to find his post. Will update when I do.
