New suspension....advice please.
Discussion in 'Suspension' started by ontarioyota, Jul 14, 2011.
  1. Jul 14, 2011 at 6:45 PM
    ontarioyota
    ontarioyota [OP] Well-Known Member
    SW Ontario, Canada
    01 reg cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Truck...2001 regular cab 4x4 Taco with worn out factory suspension..118xxx miles
    My needs
    1 -mild off-roading, hunt fish etc
    2 -carry 400-500lbs for work regularily in my bed as well as short
    towing trips pulling 2000 lb trailer when hunting(10 mile trips)
    3 not interested in lifting truck...just good suspension...I realize
    that the truck will lift a bit compared to the worn out stock
    suspension
    4- want a safer more comfortable ride while carrying a load
    After researching tons of threads here I am about to pull the trigger on an OME kit
    Just looking for advice from the many smart TW members if this is a good choice for my needs and a few ?
    Front
    OME 880 coils with 90004 nitrocharger sport struts
    Rear
    CS046RA/B OME Dakar leafs springs with 60062 nitrocharger sport shocks
    The supplier says this will give me about 2" lift...will this lift damage my CV boots with bad angles?
    Will I need a diff. drop?
    Are greasable shackles the way to go?
    Will I need to extend brake lines?
    Will my stock UCA's be OK?
    Good set up for a reg cab?
    Thank you very much for any opinions, answers and advice!!
  2. Jul 15, 2011 at 5:31 AM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Anyone??
    Is this OME kit a good choice for my needs?
    Thanks
  3. Jul 15, 2011 at 6:25 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i think the OME kits are good. i would just check that the leaf packs will be ok with the bed loaded up
  4. Jul 15, 2011 at 6:31 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You have chosen well. I would recommend greaseable front spring eye bolts as well as the greasable shackles. Your CVs will be fine, but you can add a diff drop if you would like, it will not hurt. Your stock UCAs will be fine as well.
    good luck and let us know how you make out.
  5. Jul 15, 2011 at 6:32 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    ome do not and i repeat DO NOT BUY THE PRO COMP LIFT KIT! i bought and installed it thinking it would be ok after asking the sales man and a tech at procomp well its not apparently they wait until after you install it to let you know about it.
    the pro comp 3 inch lift kit is only for v6 models thats it. my lifted regular cab got 4.75 inches of lift from this kit due to the weight of the reg cab 4cyl being much lighter. now they won't help me at all those mother fuckers.
  6. Jul 15, 2011 at 6:36 AM
    JDMcQ
    Now that Hans mentions it, I wonder how the Dakars would be on a regular cab. Mine is a DC and is fine, but the lighter weight of the RC might cause some harshness.
  7. Jul 15, 2011 at 6:36 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    :facepalm:good choice i also did not realize you are a first gen. the pro comp 3 inch complete coil kit does happen to only work with second gen v6's. ome is much much better. and god forbid something should go wrong which i doubt they will stand behind their product they are a very good company to deal with.
  8. Jul 15, 2011 at 6:42 AM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Thanks everyone...keep it coming!
    Since my Reb Cab is light with a 2.7 should I stick with the 880 coils or get 881 coils?
    I may add a brush bar in the future but no heavy bumper or winch.
  9. Jul 15, 2011 at 6:47 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    nah ome springs are very nice the only thing i have ever heard as a negative about them is they squeak a little but, alot of leafs or even adda leafs can do that. if your concerned i'm sure their are plenty of guys running these on first gens ome for the win imho its probably the best lift you can spend your money on the next step up in my book would be icon.
  10. Jul 15, 2011 at 6:51 AM
    JDMcQ
    Get the 880s for sure.
    My Dakars do squeak upon occasion, but I think that most leafs will after a while. Nothing some cleaning and lube won't fix.
  11. Jul 15, 2011 at 6:53 AM
    ontarioyota
    SW Ontario, Canada
    01 reg cab 4x4
    Yes ...it might be too stiff but I am loaded quite often...4-500lbs and the truck is used for short trips as a worker so I am willing to accept the RC loss! I have a 06 Tundra for pleasure driving.
    Also noticed in my readings that the 2nd leaf from the bottom can be removed for improved RC should it be a crazy stiff ride.
    Thanks for the input!
  12. Jul 15, 2011 at 6:56 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    yep my factory leafs squeaked a bit if i loaded the bed up now my add a leaf does the same thing. the phenomenon is not exclusive to ome by any means.
    not to mention the guys that buy the ome kit for the most part quite literally wheel the shit out of their trucks i never hear any problems with them and they are an excellent company if you ever do have an issue.
    ome is what i should have bought:bananadead:
  13. Jul 15, 2011 at 6:56 AM
    JDMcQ
    My pleasure.
  14. Jul 15, 2011 at 12:03 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Where do you find greaseable front spring eye bolts? I'm pretty sure that's the main source of periodic squeaking on my Dakars. In my lazy efforts of searching whenever it bothers me I've never found any, probably using the wrong words.
    BTW - sent you a PM in case you missed it. Or maybe you are just ignoring me, it's cool. :pout:
  15. Jul 15, 2011 at 12:08 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This eliminated my Dakar squeak
    http://www.tacomaworld.com/forum/showthread.php?p=3371352
    Sorry for the threadjack OP
    As you were gentlemen
  16. Jul 15, 2011 at 12:14 PM
    JDMcQ
    Wheelers had them. I have not installed them yet, they are sitting in the garage.
    Sorry about the PM, I read it, then got busy with something, then forgot. I will respond now.
  17. Jul 15, 2011 at 12:31 PM
    Enigmaaron
    PA
    1st gen superiority
    WTF have they always had them? I'm pretty sure I bought my leafs and rear greasable hangers from them, not sure how I could have missed that.
    And no worries on the PM, you seem like a busy man.
    To answer some of the OP's questions:
  18. Jul 15, 2011 at 12:35 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    We're talking about a first gen here. I don't think anyone recommends replacement upper control arms for first gens.
  19. Jul 15, 2011 at 12:37 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also, since you're interested in minimal height gain - definitely go the 880s rather than the 881s, especially considering it's a 4 banger regular cab.
  20. Jul 15, 2011 at 12:48 PM
    Enigmaaron
    PA
    1st gen superiority
    They do, I don't get it, but they do. To each their own.
