New Taco jittery ride
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TJH1224, Sep 23, 2021.
  1. Sep 23, 2021 at 3:42 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    I have a 2018 Limited and I’m pleased with the ride. It’s not as smooth as my 2012 Tundra, but considering the shorter wheelbase and stiffer suspension, I’m pleased overall. My empty passenger seat gets jittery when it’s left towards the end of the slider track towards the back. If I push it to the middle of the track the jitteriness goes away. Hope this helps
    TJH1224[OP] and davidstacoma like this.
  2. Sep 23, 2021 at 4:27 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Check them cold, like first thing in the AM before driving anywhere. I wouldn't go below 30 in the front. with an empty bed you could probably go below the sticker a bit in the rear. start at spec if its a touch high and see how it feels. go down from there if you feel the need. more than a couple psi below the sticker spec is asking for trouble/excessive wear/etc.
    davidstacoma likes this.
  3. Sep 24, 2021 at 7:13 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It took some time to get use to the ride of my 2020 tacoma after coming from a very plush 2001 tundra. I think like my dealer claimed, those tacoma's tend to ride better once they accumulate at least 5k miles. I'd have to agree..at 11.7k miles my truck does feel more compliant on the roads here compared to what it did over a year ago.
    TJH1224[OP] likes this.
  4. Sep 24, 2021 at 7:24 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    My stock SR handles and drives very well, I run 32 psi in the tires per the door sticker. I recently had the 10,000 mile service, tires rotated, etc and on the drive home it was a harsh jarring over bumps ride and the steering was twitchy. After I got home I let it cool down and found they had set the tire pressures to 37 psi. Lowered it back to 32 psi and it was fine handling and sure steering again.
    that tire sticker means something for stock tires, that’s where your best ride is.
    TJH1224[QUOTED][OP] likes this.
  5. Sep 24, 2021 at 7:30 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    My new stock OR shocks and no extra rear weight it felt like the rear axle fluttered a lot going over bumps. Just that kind of squirrely feel, like it takes a second to get the wheels back on the ground tracking straight.
    Adding ~100lbs weight in the rear makes a significant difference on stock truck.
    New 5160s and a little weight from a aluminum tonneau took care of it for good.
  6. Sep 24, 2021 at 7:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP, concur with the others. Reduce the COLD tire pressure to the pressure on the placard on the drivers' door jamb.
    Then open the Owner's Manual, look up the TPMS information. Read it. This will detail the purpose of the "handy pressure monitor on the dashboard".
    If that doesn't solve the "jittery" then have the dealer run a tire balance.
  7. Sep 24, 2021 at 9:15 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    They all ride like that. My 15 sport with 5100s does and so does my 3rd gen sr5. Some are just more sensitive to it then others.
  8. Sep 24, 2021 at 9:30 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I've never noticed a real difference with tire PSI. Sometimes I'll fill up to 28/29 and sometimes I'll fill up to 37ish and I really don't notice a difference in how the truck handles to be honest. maybe because I don't have a swaybar so its always just doin its own thing.
  9. Sep 24, 2021 at 9:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Google 'chalk test' and do that to get the right pressures.
    Put a couple hundred lbs of sandbags (or similar weight) right over the rear axle and see if that helps.
    Rotate the tires front to rear. If the shake moves from the seat to the steering wheel, you have a tire problem, balance or out of round.
    Relatively free / simple things to try before unloading your wallet on suspension changes.
  10. Sep 24, 2021 at 9:51 AM
    su.b.rat
    su.b.rat broken truck
  11. Sep 24, 2021 at 11:14 AM
    TJH1224
    TJH1224 [OP] Well-Known Member
    Tom
    2021 Cement Tacoma SR5 DCLB
    Thanks everyone for the tips and input - I'm less concerned about the way it rides than I am with just making sure that this is how it's supposed to ride, if that makes sense.
  12. Sep 24, 2021 at 11:21 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Ride quality is very subjective.
    su.b.rat likes this.
  13. Sep 24, 2021 at 11:45 AM
    su.b.rat
    i decided my Tacoma should not ride like that, and i didn't like how it drove and handled from the jitters. so i went reinforcement-crazy starting with the Hammer hangers. it was one of the best things i did for my truck, and especially for my ability to enjoy driving it.
  14. Sep 24, 2021 at 11:53 AM
    zoo truck
    None
    Its the nature of what these trucks are. They do get more compliant over time, but the ride quality will never be as cushy as a full size truck like a tundra.
  15. Sep 24, 2021 at 11:56 AM
    #35
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Just get used to it. The hitachi shocks firmer ride than the off-road cushy ride
  16. Sep 24, 2021 at 12:07 PM
    #36
    davidstacoma
    David
    NC
    lol what a variety of responses, everything from normal, to tire pressures make no difference to check your tire pressure and go by the tire sticker pressure, to you need hammer hangers. If I didn’t have 45 years of driving experience and had to use the advice in this thread I wouldn’t know whether to shit or go blind lol.
    It’s really not that hard. Try using the tire sticker pressure first, tire pressure does make a difference in ride, it’s physics. If that doesn’t help then see if you can get a ride in a another stock truck like yours, make sure to ask what tire pressure they run. Is it the same ride with the same tire pressure? Then it’s normal. And so on until you find a real fix or decide to live with it. I wouldn’t go throwing parts blindly at any problem.
    TJH1224[OP] and jmneill like this.
  17. Sep 24, 2021 at 12:23 PM
    #37
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    run 28-30 psi in the rear. 32 psi is too high if you have nothing in the bed. causes it to bounce.
    zoo truck likes this.
  18. Sep 25, 2021 at 4:42 AM
    #38
    zoo truck
    None
    Idk, if thats more bs, or not. I've ridden in my buddies 2019 trd or that its back to stock now...no more lift. It has all the oem bilsteins back on. That tuck doesn't ride really any better than my 2020 sr5 on the roads here. I can't even tell much difference on our dirt road.
  19. Sep 25, 2021 at 5:43 AM
    #39
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Lol
  20. Oct 4, 2021 at 11:13 PM
    #40
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    With no load our Tacomas just ride like the pick-up trucks that they are.
    --Try adding 100 or 200 lbs of sand bags (1/2 of it near each rear wheel). Its cheap (less than $5 per 50 lb bag at HD or Lowes). I put my sand bags inside garbage bags to keep the sand that leaks out of the paper bags from making a mess.
    You will be amazed at the difference in ride. Jitteriness gone.
    --As for all those who say change your shocks or springs--don't fall for it. Try this really easy and cheap fix first
    Also helps with traction in wet or icy weather--something I don't worry about now that I live in Arizona.
