New Taco owner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StompinStu, Jul 6, 2008.
  1. Jul 6, 2008 at 8:06 PM
    StompinStu
    StompinStu [OP] Active Member
    Baton Rouge, LA
    06 PreRunner Access Cab I4 5 speed
    I have been a "Jeep man" my whole life. I've had 4 vehicles and they have all been a Jeep. Jeep makes nothing that appeals to me these days, so I went after something I liked for a lot of reasons.
    Got a 2006 PreRunner Access cab. Very happy with the truck, but would like to upgrade some aspects of it
    What I want to know is:
    -can OEM power windows and locks be retrofitted?
    -can OEM fog lights be retrofitted?
    -can OEM keyless entry be retrofitted?
    -I can get a OEM 6-disc changer for cheap....how hard of an install is this?
    -What type of aftermarket radios fit the factory dash housing?
    I'm very happy with this truck, and want to do these few things to enhance my enjoyment.
    Here's the truck
  2. Jul 6, 2008 at 9:10 PM
    MikeS.
    MikeS. Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    I believe your 06 AC is basically the same as my 08 DC. With that the fog lights are easy, the wiring is probably there. The 6-cd should be easy too. The dash is a double DIN unit.
    Your other ?s I just don't know. But from reading here a lot of the trucks have the wiring harness and you have to connect the modules.
    Now if you have crank windowes then you are going to have some work to make them elec.
  3. Jul 6, 2008 at 9:11 PM
    MikeS.
    Far Eastern WVa
    Ohh, and welcome to the Toyota addiction.
  4. Jul 7, 2008 at 6:12 AM
    tjdriscoll
    tjdriscoll Active Member
    07, Tacoma Std Cab, 2WD, 5-M, 2.7 L I4, Indigo
    OEM Foglights, iPod adapter, Bedlights-Underbody lights, more to come soon.
    dude, i was the same way with the jeeps. i loved the wrangler and always wanted to get one and turn it in to an off-roader. but ever since they changed to body style in 2006-2007 i can't stand the look of them anymore.
  5. Jul 7, 2008 at 6:17 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Welcome to the group, sorry I can't help.
  6. Jul 7, 2008 at 6:25 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I personally like the JK better than the TJ or YJ. Especially the 4 door Rubicon(s).
  7. Jul 7, 2008 at 9:19 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    you can fit pretty much any single or double din aftermarket units in this w/ the correct dash kit
  8. Jul 7, 2008 at 12:44 PM
    StompinStu
    Baton Rouge, LA
    4 doors and weak engine options are why I don't like the new Jeeps. The 4.0 straight 6 was a great engine. Excellent low end HP and torque. The new Jeep 3.7L V6 is rated higher in both categories, but you gotta wind it up to higher RPMs to get it. Which in the off-road world is not always a good option.
  9. Jul 7, 2008 at 2:18 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    I don't see listed if it is a 4 or a V6, if it is a 4, the foglamp wiring to the bumper will most likely not be present.
