new tacoma......what is a-trac?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFreak4O7, Mar 29, 2014.
  1. Mar 29, 2014 at 9:28 AM
    TacoFreak4O7
    TacoFreak4O7 [OP] Well-Known Member
    Zachariah
    Orlando
    2014 Black 4.0L V6 Tacoma Double Cab TRD Off Road
    I <3 TACOS Sticker, Grey Soft topper
    what is a- trac and how does it differ from traction control?
  2. Mar 29, 2014 at 9:35 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Active traction. Its work only in 4 low. It applies brakes to tires with no traction to shoot power to tires with traction. Works really well while 4 wheeling.
    VSC is traction control to aid in preventing you from loosing control of the vehicle.
    Trac is meant to limit engine power when tires start to spin too much.
  3. Mar 29, 2014 at 9:36 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's only available on '09+ TRD Offroad 4x4 models
  4. Mar 29, 2014 at 10:32 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Click on the link in my sig for a pretty full read... http://www.tacomaworld.com/forum/2n...-controls-trac-auto-lsd-trac-rear-locker.html
    I have had 3 Tacomas, and the third has A-TRAC... it makes the truck climb, pull, get out of problems like a Sherman Tank. The closest way to describe it is it is like automatic front and rear lockers... if any tire begins to spin from loss of traction, the A-TRAC applies just enough brake to that tire to balance power to the other tire on the axle.
    It differs from TRAC in that it stops spin like a locker, and not just limits spin. I found that you do need to mash the pedal if your truck stops moving in a hill climb using A-TRAC, and the system wakes up and pulls you onward. I have video clips of that happening (One Tri Hill). Also of me pulling a 2WD stuck truck using A-TRAC. See the two links in my sig.
    Note: In 2012, a 10th drive mode was added in H4. TRAC in H4 now has engine regulation and the new unregualted traction control is called TRAC OFF and requires a quick push of the VSC button.
