New Tires...Unusual Rubbing
Discussion in 'Wheels & Tires' started by sac130e, May 2, 2011.
  1. May 2, 2011 at 12:36 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Details for Front End:
    5100's @ 0 w/OME 884 Coils; LR UCA's
    Rear End"
    5100's w/TSB and 1.5" AAL
    Wheels/Tires:
    MotoMetal 955 w/ BFG TA KO @ 275/70/17
    Alignement is still being adjusted, first place didn't quite get it right, taking to dealer to get it correct and do a look over of installed components.
    Issue is the front left tire rubs the lower front fender in reverse (see pic). Used to rub on the mud flaps (removed since), BUT never rubbed the right front in reverse..only on the drivers side.
    Anybody else heard of this, or know why only on one side?
  2. May 2, 2011 at 12:40 PM
    BackwoodsBoy
    BackwoodsBoy Well-Known Member
    Adam
    Pittsburgh Area
    06 TRD Sport
    I installed a set of new tires about 3 weeks ago and put on different wheels (xd addicts 17x9) and had the same rubbing problems... but i just took a grinder and cut a few small pieces out to get them to clear
  3. May 2, 2011 at 12:42 PM
    sac130e
    Scott
    Milton, FL.
    Main reason I went with 275's instead of 285 was to avoid rubbing/cutting problems. Just seems odd to only happen on the driver's side and not on both sides.
    Thx
  4. May 2, 2011 at 12:45 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    would the "taco lean" of the truck affect the rubbing since it might be a little lower?
  5. May 2, 2011 at 12:46 PM
    elgin
    elgin Well-Known Member
    Ian
    Southwest Colorado
    11 DC TRD OR 4x4
    its only on the left side (drivers) because the tacoma's lean to that side, get a 3/8" top plate spacer on that side and it will probably fix the rubbing.
  6. May 2, 2011 at 12:50 PM
    BackwoodsBoy
    Adam
    Pittsburgh Area
    06 TRD Sport
    Still cheaper to jus do a little trimming... just my opinion
  7. May 2, 2011 at 12:55 PM
    DevL
    DevL Well-Known Member
    Wont it still rub under compression when turning?
  8. May 2, 2011 at 1:32 PM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    I threw on a set of XD revolvers in 17x9 and had the same rub. It's the back spacing of the wheels...A box cutter will go right through that thin plastic, I had to trim mine as well in the same place.
  9. May 2, 2011 at 1:35 PM
    sac130e
    Scott
    Milton, FL.
    I installed the 1/4" spacer from Toytec to get rid of the taco lean.
  10. May 2, 2011 at 1:36 PM
    sac130e
    Scott
    Milton, FL.
    I hear you, just hate cutting the actual fender for this. Since the local tire shop did not touch the UCA's during alignment (another issue all together), I will see what the dealer gets when they do the alignment correctly. maybe alittle adjustment will get rid of some or all of the rub.
    Thx
