New tires will they rub?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cinchman19, Jun 30, 2020.
  1. Jun 30, 2020 at 11:41 PM
    Cinchman19
    Cinchman19 [OP] Active Member
    Mark
    Las Vegas
    2001 2wd prerunner v6 Tacoma
    Hey guys I have a icon lift at 2.75in and a spc uca. Just got some new wheels 16x8 0 offset. And 285/75/16 Patagonia MTs. Will I rub on the frame rail? Should I get spidertrax wheel spacers?
    Taco critter likes this.
  2. Jul 1, 2020 at 12:40 AM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    You’ll likely rub. You can either get different wheels with less backspacing, you’re at 4.5 now, shoot for 4 or less, the lower you go the more you’ll poke out. You likely won’t have to worry about rubbing on the fender with your lift, but you may rub on the pinch weld, that’s an easy fix with a hammer though, or adjusting castor.
    Spacers will also get you off the frame.
    I personally prefer to have the wheels handle that task.
    ps. I am FAR! from an expert here and just going off what I’ve read, I haven’t run that set up. Hopefully someone who has will chime in and show that I’m wrong and you won’t have any issues!
  3. Jul 2, 2020 at 4:06 PM
    ECO Lander
    ECO Lander Well-Known Member
    You’ll rub.
