New to Suspension Mods
Discussion in 'Suspension' started by LarrysWorld, Dec 17, 2015.
  1. Dec 17, 2015 at 10:06 PM
    LarrysWorld
    LarrysWorld [OP] 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    Now I've never ever changed my suspension on any of my Tacomas that I've had. One, because I didn't know how and two, I really couldn't afford it. So, I've got plans to get a hybrid front bumper and I'm installing 31x10.5x15 Falken Wildpeaks ATs. Now I know I need new suspension so I thought I'd upgrade to some new ones. I don't do much off-roading but I do here and there. Not sure there are some shocks that give you some type of lift or not. What do you all recommend I go with? :mudding:
  2. Dec 18, 2015 at 10:23 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If all you are wanting to do is level it out and compensate for the weight of the bumper, then a set of Bilstein 5100s is probably your best bet.
    LarrysWorld [OP] likes this.
  3. Dec 19, 2015 at 1:25 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    So I've seen Three types of 5100 series bilsteins,
    5100 Lifted Light Truck/SUV
    5100 Ride Height Adjustable
    5100 Steering Damper
    Now I don't want to change the height of my truck because I think it sits pretty well right now, what would be my best bet out of these three options?
  4. Dec 19, 2015 at 1:30 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    We've had a lot of problems with the 51 series from bilstein up here, mostly due to cold I think, so OME gets my vote. Can't seem to keep them on the shelf up here.
  5. Dec 19, 2015 at 1:33 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    I'm not trying to lift my truck though. I just want a smoother ride.
  6. Dec 19, 2015 at 2:11 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    I got the 5100 for my front and rear, I love em so far, they do stiffen up the ride a little more but handling improved overall. You don't get that squishy feeling around corners or over bumps, the truck feels much more planted to the ground and feels great on the highway. I have my front set at the 3rd notch which raised the front end nearly 2 inches.
    It however made the front about 1-1/2 inch higher than the rear, driving around with the front higher made me dizzy so I forked over the money and got a set of Toytec 1.5" add a leaf for my rear, now the rear sits about 1inch higher than the fronts. I love the rake so I don't mind it, I actually prefer it, I figure once I get my Leer Canopy in it'll weight the back down. The add a leaf kit will stiffen the rear end, but for a good cause because I believe the Tacoma leaf springs are super soft thus the truck likes to sway around a lot.
    Just by doing the suspension mods I have done really improved the ride, my back no longer hurts on long drives, I drive an hour to work everyday and an hour back home.
    I would recommend the Bilstein 5100's they are definitely better than the OEM Bilsteins.
    If you set them to the first notch up front and just install the rear as is without a lift, I really think you'll like them. They ride really good, The cold hasn't affected mine at all.
  7. Dec 21, 2015 at 1:47 PM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    So I've been doing some research and I'm looking to get the bilstein 5100 series. But these websites keeps telling me that my truck needs the 4600 series. I have an 05 regular cab Tacoma 5 lug.
  8. Dec 21, 2015 at 9:13 PM
    httuner
    I ordered mine from 4wheel parts, If you get both front Struts and 2 rear shocks and add them to your shopping cart individually and not buy the Package offer they got, you can save more money by using this coupon code: CC5OFF. The coupon code does not work when you buy the strut/shock package. Always nice to save.
  9. Dec 30, 2015 at 6:18 PM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    so i recently just bought a tacoma. 2012 TRD sport double cab, short bed. I want to lift it an inch or so, not more than 2 so i can put some bigger A/T tires. I live in new england and we're about to have a crazy winter. if i get 4 5100's for the front and rear, will that be good enough? or will the rear be higher than the front like it happened to you
  10. Dec 30, 2015 at 8:03 PM
    httuner
    Setting the front to 1.75 caused my front to be about 1inch higher than the rear. It bugged me so that I lifted the rear 1.5inches using an add a leaf kit so that made the rear 1inch higher than the front which I like more and actually prefer. Having that rake really improves the driving experience, at least for me.
    Now it may differ for you. I've seen some, where setting the front to 1.75inch actually leveled the entire truck just fine.
    Set it to the second notch from the bottom at .85inch I think and that will give you the 1inch lift you want for the front, if setting it at 1.75 (3rd notch) causes your front end to be higher than your rear unless of course you like a higher front end. Lol sorry it's kind of a mess to explain.
  11. Apr 12, 2016 at 6:25 AM
    GoLongJoe
    GoLongJoe Well-Known Member
    Joe
    2005 Tacoma PreRunner -- 2WD Project
    Tires, soon to be shocks, bushings, and bull bar. No lift, not needed.
    Awe man, is this thread dead? I'm needing some of the same advice. I have a 2wd 6 lug Prerunner that I like to take trail riding a couple times a month and go camping in remote NorthGA mountains once every 2 months. Obviously, that's taken a toll on the stock suspension and it's starting to squeak. I'm buying in pieces for now to put it all on at once. I'm getting new polyurethane bushings for front and rear, haven't really decided on shocks yet (thinking Bilstein), wanting to replace my springs at the same time (I think the fronts are good, back really needs new ones). I'm buying new rotors this weekend (much needed) and most likely going with Centric Premium High Carbon Brake Rotors
    and found a great deal on a camper top I just couldn't pass up, Though I know that's going to kill my shocks even more.
    So that's my plan for now. I guess my biggest concern is, does this seem like the best course of action? I'm still not made of money but I'm getting better. Let me know what you guys think, if you're still there.
  12. Apr 12, 2016 at 6:36 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    For what it's worth, I put 5100's all around with the front at 1.75 and it leveled me out completely. But down the road I put Eibach 620's and set the bilstein back to 0.
  13. Apr 12, 2016 at 6:41 AM
    GoLongJoe
    Joe
    Did that lift it? I looked at Eibach and it looked like they were for lifts.(EDIT: just looked closer and saw they don't lift the Tacoma.) I'm like the last guy, hoping to keep my height the same stock height. It already has the highest stock ground clearance of all the trucks, full and mid size. The difference between he and I is that I have the 6 lug access cab. He just has regular 5 lug so they may suggest different shocks for him.
  14. Apr 12, 2016 at 6:59 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Well I have a double can V6 4x4, so it might be different for you. The Eibach coils didn't lift me too much honestly it's about maybe a half inch higher in front than it was stock. The bilsteins at 1.75 and stock coils gave me more lift but the ride was shitty
  15. Apr 12, 2016 at 7:06 AM
    GoLongJoe
    Joe
    Yeah, the 4x4 adds about 400lbs of weight in the front, which is why I want to keep it 2wd. I know that limits my off roading but I only trail ride, nothing too serious. Just want it to be more comfy for my lady friend and my dog. Thanks for the input. Have you updated your brakes? If so, what'd you replace the stocks with?
  16. Apr 12, 2016 at 8:54 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    no problem. The pads and rotors are OEM
  17. Apr 13, 2016 at 12:17 PM
    GoLongJoe
    Joe
    Really? That's what my buddy was telling me but I didn't want to believe him. Gotcha!
  18. Apr 13, 2016 at 12:20 PM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    So i bought the truck used at 58k, the car fax said that the front pads were changed at 53K at the dealer. its at 63k now. im assuming the rotors are OEM original too. I plan on getting new/better pads though. nothing wrong with the brakes but i personally like strong braking power, enough to jerk you outta your seat
  19. Apr 15, 2016 at 1:29 PM
    GoLongJoe
    Joe
    Agree, I'm going with OEM rotors (my truck has 214k + miles on it and still going strong, no leaks at least) but since I want new shocks and bushings sooner than later, going OEM sounds good to me. I'll get the ceramic pads though
