New to trailering, do I need more leaf springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by padykman, Mar 25, 2011.
  1. Mar 25, 2011 at 9:51 AM
    padykman
    padykman [OP] Active Member
    Paul
    Meridian, Idaho
    10 Dbl Cab TRD 4x4
    Leer Shell Outlet plug in cabin
    Hay All,
    I am a bit new to towing and have a leaf spring question. I will need to tow ~3k trailer and wondering if the stock springs will squat to much. Also if there a TSB that will add a 4th spring so that I am not nose up when I hook up the trailer or will I need to go with some after market product. I am alos adding a trailer brake.
    2010 TDR OR DC V6 auto.
    Thanks in advance for any info gleaned.
  2. Mar 25, 2011 at 10:22 AM
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    You might check the TOWING thread for more info. Also, I tow a travel trailer with my 08 Taco with the towing package. I use an equalizing hitch, installed the spring TSB, and air bags. When towing with the stock rear springs (no TSB or air bags) it was unstable when towing in wind, on bumpy roads and passing large vehicles. My setup, now, is very stable. Hope this helps.
  3. Mar 25, 2011 at 10:32 AM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    If you like the stock ride just get some airbags. If you want a stiffer ride without a load get the TSB and add the Airbags. I like the Airbags a lot. You can have both a soft ride with them when not used and a stiffer suspension when needed.
