New to TW and looking for ideas.
Discussion in 'New Members' started by MontanaYoter, Mar 9, 2010.
  1. Mar 9, 2010 at 5:26 PM
    MontanaYoter
    MontanaYoter [OP] Well-Known Member
    Henry
    Bozeman, MT
    1983 Toyota Pickup. A tacoma from before tacomas were tacomas
    Lots of rust
    I just bought an 01 Tacoma a month ago and im looking to personalize it.
    My name is Henry and I'm a poor high school kid.
    Any suggestions for my truck?
  2. Mar 9, 2010 at 5:27 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  3. Mar 9, 2010 at 5:37 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
  4. Mar 9, 2010 at 5:41 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Welcome man.
    Deck plate and the Rear diff breather relocation. Maybe some lights or something How bout this?
    A few of you guy's asked about how I mounted these, so here goes.
    I started by taking a run to Home Depot to see what I could figure out. Here's what I came home with:
    -2 2" tall L-brackets
    -2 really long nuts, 5/8" maybe? The same size as the mounting bolt for the Hellas, and were about an inch or so long.
    -2 bolts, the same size as the long nuts I bought. I think they were 1.5"-2" long.
    -A bunch of washers.
    -1 1" wide metal plate thing.
    First I figured out where I wanted the lights, then I took the grill off and drilled some holes for the L-brackets. The holes are all under the grill, so if you take the lights off later on you won't be able to see them (hopefully).
    Well, then I bolted the brackets to the bumper and tried to put the grill back on. That didn't work so well, the grill wasn't able to slide behind the brackets into the right spot. So...I took the brackets back off, set them on the ground, and gave them each a good stomp, so they were flat, then reatteched them to the bumper. The grill now went back on, and all I had to do was bend the brackets back up to the right spot.
    Then I bolted the lights to the brackets and attached the really long nuts to the remaining length of bolt left from the light. Then I cut that flat 1" wide metal piece into 2 2" or so long strips and drilled a 5/8" hole in the middle of each one. These pieces are to brace the light to the back of the grill to keep them from bouncing around. I stuck the bolt with a bunch of washers for spacing through those metal strips and screwed it into that really long nut.
  5. Mar 9, 2010 at 5:48 PM
    MTgirl
    Weesa
    Bob's secret mod lair
