New truck 4x4 questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Padaurizio, Apr 8, 2011.
  1. Apr 8, 2011 at 9:31 AM
    Padaurizio
    Padaurizio [OP] Member
    Phil
    Cheyenne, WY
    I recently bought a new Tacoma, but I never put it in 4x4 before I bought it or tried 4x4 on any of the trucks I test drove. When I got it home I was playing with the 4x4, and I am wondering if it is normal for it to not go into 4 low from 2 high when stopped and in neutral with the clutch in or out (tried both). It has no problem from 2 hi to 4 hi, then 4 hi to 4 low. It also makes a clunk when shifting the transfercase. The rear diff lock also seems slow, but I am more familiar with ARB lockers and manual shift transfercases. Please tell me if this is normal, or if it is something that I will need to take back to the dealer. The truck only has 1000 miles on it.
    It also has an occasional slight vibration at idle, but I think that is normal because most of the trucks I test drove had a small vibe.
    Thanks for the help
  2. Apr 8, 2011 at 9:41 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    You must be in 4Hi before the case will shift to 4Lo. In neutral and clutch all the way to the floor if you have a manual. E-Locker is slower to engage versus an ARB all day long.
  3. Apr 8, 2011 at 9:41 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Normal. Has to go into 4hi before 4lo is available. :)
  4. Apr 8, 2011 at 10:20 AM
    Padaurizio
    Phil
    Cheyenne, WY
  5. Apr 8, 2011 at 10:24 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    should be a "how to" card stuck in the drivers side visor
  6. Apr 8, 2011 at 12:45 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    I think after you get in 4HI (while rolling) you then have to stop (or 2mph) before putting in 4LO (4LO engages after you move a few feet)
  7. Apr 8, 2011 at 2:17 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    This card explains it clearly.
  8. Apr 8, 2011 at 6:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
