New truck no start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drucilla, Oct 29, 2009.
  1. Oct 29, 2009 at 5:18 PM
    drucilla
    drucilla [OP] New Member
    colorado
    09 Tacoma 4x4
    10k miles and periodic no start!
    turn key and just a labored whooshing sound- no engine turnover. return hours later and the truck starts after cranking over for a full 10count... odd.
    then its fine for days. dealer is confused....
    anyone else??? ideas???
  2. Oct 29, 2009 at 5:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Sounds to me like a grounding issue, or the starter is dying...
  3. Oct 29, 2009 at 6:07 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Hmm... I've had some periodic starting problems on my 09 as well... It always cranks over but sometimes it's hard to start - it'll turn over for a while and then I'll key it off, crank it again and it usually starts up.
    I know the earlier models had an intermittent no start TSB for extended cranking, but why is the 09 having issues :confused:
  4. Oct 29, 2009 at 8:58 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    sounds to me like the starter is working but the engine isn't turning over.
    fuel delivery issue????
  5. Oct 29, 2009 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    there was a TSB on this a while back. Take it in. They reflash the ECU.
  6. Oct 29, 2009 at 9:15 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Had the same problem on my 07 when it was new. The TSB to fix it back then was...TSB EG011-07 for recalibrating ECM to correct OP Code EG5054 T1-T2-99. After the recalibration I haven't had the problem since.
  7. Oct 29, 2009 at 9:18 PM
    jar-sr5
    jar-sr5 Active Member
    Manitoba, Canada
    tacoma SR5
    Grille Craft, 245/75/16 Wrangler Duratracs
    yeah i also have this problem and I hate when it does that.
    so a dealer can perform a old TSB to a newer vehicle?
  8. Oct 29, 2009 at 9:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.......tsb for it.............dealer should square it away by reflashing the ecu as chris said. they did it for my 06 when i was having the prob, and it was fine afterwards.
  9. Oct 29, 2009 at 11:11 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If any of you get your 09' ECU flashed via TSB, please post back here and let us know. I think mine may be having that issue too. Thanks
  10. Nov 1, 2009 at 9:15 AM
    jar-sr5
    Manitoba, Canada
    tacoma SR5
    someone needs to make this topic a "sticky"
    it seems to be getting more and more common.
  11. Nov 1, 2009 at 11:29 AM
    aaronk
    2009 Dbl Cab V6 TRD
    Uhh, the TSB was never for the 09 :confused:
  12. Nov 1, 2009 at 12:19 PM
    jar-sr5
    Manitoba, Canada
    tacoma SR5
    yeah that's what i thought. but i wasn't sure.
  13. Nov 1, 2009 at 6:25 PM
    drucilla
    colorado
    09 Tacoma 4x4
    i'll ask the dealer aboot any tsb's and aboot the old tsb code...
  14. Nov 2, 2009 at 6:27 PM
    jar-sr5
    Manitoba, Canada
    tacoma SR5
    ok thanks. much appreciated
