new u-bolts required???
Discussion in 'Suspension' started by Tsenekos, Sep 9, 2009.
  1. Sep 9, 2009 at 7:59 PM
    Tsenekos
    Tsenekos [OP] Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    waiting for my order to arrive but was wondering if you need to use new ubolts(longer) with the rear aal that comes with the 3" toytec lift? I also ordered shims. I looked under my truck and the stockers have about an inch of thread left. will that be enough?? thank you :confused:
  2. Sep 9, 2009 at 8:04 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    I don't think you have to but everyone here will suggest it since they are so cheap and I think you can stretch out the threads and weaken them. Someone will chime in with a forsure answer on whether or not they are mandatory.
  3. Sep 9, 2009 at 8:18 PM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    I bought a new set of u-bolts when I put my AAL and shims on. Without the longer u-bolts there wasn't a lot of thread left on the stock ones. Plus you can usually pick them up at any auto store for next to nothing.
    Just cut off the extra threads when you get the new ones on.
  4. Sep 9, 2009 at 8:35 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I think it is recommended to never re-use U bolts. I could be wrong though
  5. Sep 9, 2009 at 8:42 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    All those u-bolts found in auto stores are cheap junk. They'll work, but for about $25 more you can get some nice 1/2" USA steel grade 5's instead of that grade 3 china stuff. I have 3 u-bolt options from grade 3 junk to grade 5 quality with grade 8 hardware and then monster 9/16" grade 8 with high nuts and thick flat washers. Square or round, quality is the way to go when it comes to u-bolts, just like blocks.
    grade 3 china
    1/2" grade 5 USA
    9/16"" grade 8 USA
  6. Sep 9, 2009 at 8:48 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    where did you get the 1/2" ones from?
  7. Sep 9, 2009 at 9:35 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    The 1/2" gold ones are grade 3 pep-boys specials with my upgraded hardware and the 1/2" grade 5's below them are custom bent for me at a spring shop I do business with. They are much nicer than most commonly found. The threads aren't cut as deep, which means there is no play in the nut.
