New VFtune install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wrightme43, Jun 11, 2020.
  1. Jun 27, 2020 at 10:02 AM
    #161
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Don't you need a login to TIS to actually download the .cuw files though? That part I didn't understand, and hoped there was a repository of those files linked on TW to choose from. if not, that would be a great resource.
  2. Jun 27, 2020 at 11:26 AM
    #162
    wrightme43
    wrightme43 [OP] Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    The links to the update files are in this thread.
    tonered likes this.
  3. Jun 27, 2020 at 12:32 PM
    #163
    Bluesport83
    Bluesport83 Well-Known Member
    Paris, TN
    16 Tacoma sport
    Tailgate pop&lock, go rhino sport bar, P3 brake controller, window tint, vent visors,color matched trim vinyls,reflective tailgate vinyls, siren speaker, federal signal ultra thin lights, rekgen mud flaps, coverking seat covers, retrax retractable bed cover,CBI overland skids and 2inch toytec lift
    how do you get the license code for techstream made it to the system id but couldn't get the license coded
  4. Jun 27, 2020 at 2:07 PM
    #164
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    But no speedometer adjustment for larger tires?
  5. Jun 27, 2020 at 2:42 PM
    #165
    Shellshock
    Iowa
    Nope. He’s looked but that seems to be controlled by a different ECU. The shift points can be adjusted though for tires / gears
    tonered likes this.
  6. Jun 27, 2020 at 2:51 PM
    #166
    Jasonstacoma
    Stock
    I'll just adjust my speedometer to adjust back to normal shift points. It makes no sense e to adjust for shift points but still have incorrect readings.
  7. Jun 27, 2020 at 2:53 PM
    #167
    Shellshock
    Iowa
    Adjusting the speedo does nothing to modify shift points
    tonered and MOC221_ like this.
  8. Jun 27, 2020 at 2:54 PM
    #168
    Jasonstacoma
    Stock
    Factory sr5 tires are 30.4 inches, I went to 33.2, puts me off 9 percent. I can tell a big difference.
  9. Jun 27, 2020 at 2:55 PM
    #169
    Jasonstacoma
    Stock
    I honestly don't mind shift points how they are, I'm more concerned with the 9% off I am for mileage and factory shift points
  10. Jun 27, 2020 at 7:39 PM
    #170
    Jasonstacoma
    Stock
    My truck will be at a speed 9% off of where it thinks I actually am, affecting when my truck shifts. I can definitely tell a big difference at wot.
  11. Jun 27, 2020 at 7:52 PM
    #171
    Shellshock
    Iowa
    Your shifts are off because of the tire size change. Correcting the speedo is only going to make the speedo read accurate. The truck is still going to shift in the same places it is now. The only way to correct shift points for larger tires or gears is tuning. Speedo correction is only a display. The truck is still going to think it has stock sized tires.
    ryanhealy and patdeezy like this.
  12. Jun 28, 2020 at 1:50 PM
    #172
    PThy
    PThy Well-Known Member
    Pat
    SoCal
    2020 TRDOR MT
    First off, big thanks to wrightme43 and tonered for this huge contribution of time and energy!
    Steve, great write up; articulate, in depth and easy to follow and understand.
    I'm new to Tacomas and new to this site. Recently purchase a 2020 TRDOR with MT. I really enjoy the truck, but also am unhappy with the main reason this thread exists. Such a bizarre power band. I am very interesting doing this mod, even looking at new laptop to make it happen (so happens I was on the fence about sticking with OS or not - this will sway that). At this point the only thing holding me back is I wonder how this tune affect my warranty. Anyone have any idea on that?
    Thanks Guys!
    Pat
    tonered and wrightme43[OP] like this.
  13. Jun 28, 2020 at 2:53 PM
    #173
    wrightme43
    It is invisible to Toyota as far as I understand it. Techstream can't see it. It changes what they did. The only change I noticed is it makes feel like it I imagined it would from the factory.
    PThy likes this.
  14. Jun 28, 2020 at 3:09 PM
    #174
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Don’t let the tune option sway your choice of OS. I bootcamped my 8 yo MacBook Pro and all is good.
    PThy[QUOTED] and Shellshock like this.
  15. Jun 29, 2020 at 10:46 AM
    #175
    PThy
    Pat
    SoCal
    2020 TRDOR MT
    Excellent, thanks Steve!
  16. Jun 29, 2020 at 10:47 AM
    #176
    PThy
    Pat
    SoCal
    2020 TRDOR MT
    Thank you Rush, good to know.
  17. Jun 29, 2020 at 11:57 AM
    #177
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The most current TSB CUW files are in a few threads on TW. I know they are in this one for sure:
    https://www.tacomaworld.com/threads/software-update-for-the-manual.562550/
    MT: 04B13 and 04A71 are attached to the first post and Post 199.
    AT: 04B04 and 04A61 are attached to Post 184.
    MT: 04B14 is attached to Post 3050.
    I'm off by 5% with my ATs. NBD. I just add 1mpg at 20mpg. Otherwise, I don't really care about the ODO. That's just me.
    You're welcome! :cheers:
    Technically, tuning will void the warranty on any vehicle. That said and IMVHO, OVT is much better for your motor and your driveline than the janky stock tune. I have a smoother motor that does not ping. I don't hear the driveline getting knocked around by the wonky throttle control. From that, I would expect to not only make it through the warranty period with no issues, but have much better longevity down the road.
  18. Jun 29, 2020 at 12:02 PM
    #178
    Shellshock
    Iowa
    Same. I’d be much more worried about the wonky shit the stock tune is doing negatively impacting longevity of this truck.
  19. Jun 29, 2020 at 12:05 PM
    #179
    su.b.rat
    su.b.rat broken truck
    also I'm agreeing with whoever said 04B14 is smoother than B13. the difference is significant, motor seems to idle and return to idle much more smoothly than before. that was you, right @Shellshock ?
    wrightme43[OP] and tonered like this.
  20. Jun 29, 2020 at 12:05 PM
    #180
    wrightme43
    This 1000 times.
    tonered and su.b.rat like this.
