new wheels and TPMS ?
Discussion in 'Wheels & Tires' started by nb_tacoma, Mar 6, 2011.
  1. Mar 6, 2011 at 12:31 PM
    nb_tacoma
    nb_tacoma [OP] Well-Known Member
    nick
    Thunder Bay, ON
    2006 SR5 access cab 4x4
    2.5 inch toytec lift /w rear block 255/85/16 cooper discoverer st's Westin light bar with 2 hella 500's Satoshi grille mod BHLM bumper valence painted with rocker guard relocated the horns tail gate anti-theft mod added a trailer hitch relocated 7 pin in bumper rear diff breather mod Magnaflow muffler kenwood KDC-X895 deck
    hi all,
    I am in the market for new wheels and was wondering about the TPMS, if you guys put them back in the new wheels, or just replaced with normal vavle stems, and if you went with normal valve stems is there a way to get the light on the dash for the tpms to turn off?
    thanks in advance
  2. Mar 6, 2011 at 12:34 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i dont believe there is a way to get the light to turn off. most people just ignore the light, or put a piece of black electrical tape over it.
    if there is a way to turn it off, i would assume it is a fuse so check your fuseboxes to see if any of them are marked for TPMS
  3. Mar 6, 2011 at 12:44 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    If you can just put the TMPS in the new rims. If you can't keep them and place them in either a small tractor tire or build pressure vessel out of PVC and inflate those to 35psi to get the light to go off. Just look for a good hiding spot in the truck. Or worst case take off the light from the board.
  4. Mar 6, 2011 at 4:46 PM
    Detective_Dan
    Colorado Springs
    i was talking about if there was a single fuse only for the TPMS light, but not if there are other dash warning lights wired into the same fuse
  5. Mar 8, 2011 at 11:06 AM
    imrocksolid
    imrocksolid Active Member
    11 SR5
    Morimoto mini-DS2 retrofit with blacked out headlights, All-Pro rear bumper, URD Short Shifter, Extang Tri-Fold, charcoal filter delete, aFe pro dry filter, shorty antenna
    Is this the same for the new '11 Tacoma?
  6. Mar 8, 2011 at 11:08 AM
    Detective_Dan
    Colorado Springs
    more than likely, yes
  7. Mar 8, 2011 at 11:12 AM
    imrocksolid
    11 SR5
    Thanks, I'm picking one up soon. Has the steel wheels and they need to go. New to the Tacoma so I'm trying to read up on mods.
  8. Mar 20, 2011 at 4:25 PM
    imrocksolid
    11 SR5
    How hard is it to get to the TPMS ECU? I've never taken apart a Taco dash before and it looks like I'd need to do that to get to the ECU.
  9. Mar 21, 2011 at 12:27 PM
    imrocksolid
    11 SR5
    Nice, I'll take a look at that tonight. So that ECU only manages the TPMS, it's not going to affect anything else?
  10. Mar 21, 2011 at 4:51 PM
    imrocksolid
    11 SR5
    Toyota must have gotten smarter about the TPMS. I unplugged the wiring harness from the ECU and started up the truck. TPMS light came on and was flashing. Oh well, might have to go with the black tape mod when my new wheels come in.
  11. Mar 22, 2011 at 6:21 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    What are you going to do with the steel rims/sensors/tires?
    If you break them down, you can take the sensors out & use a band kit in the new tires/rims. The kit cost $50 & others have done that here.
    If you keep the steel rims for say winter & add winter tires mounted & aired up, you will not trigger a light unless you get out of signal range. It's pretty far.
    In the summer I drive all over the place sometimes 20 miles away, park at a trail head, go for a hike, come back to the truck & still do not have a light. Its been this way for 4 seasons on my 2006.
    Others have had same result as me here as well running two sets of tires/one set of sensors.
    If you sell the rims/tires/sensors most use the tape method or use other tricks listed on in many of the tacoma forums.
  12. Mar 22, 2011 at 6:49 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    You can also drop your spare, break the bead and use a single strap to mount all sensors in it and it will work just fine.
    The strap is basically a huge hose clamp.
  13. Mar 22, 2011 at 7:40 AM
    lopezoscar03
    lopezoscar03 Well-Known Member
    lopezoscar03@gmail.com
    i second this... i use to have a 350z and this is what we use to do when we upgraded our wheels.
  14. Mar 22, 2011 at 9:10 AM
    imrocksolid
    11 SR5
    I'm planning on keeping the stock tires mounted on the steelies in my garage to run in the winter so I didn't want to break them down. I saw some of the other mods but I don't want to do any cutting of wires and I have no clue how to get the gauge cluster apart to remove the LED.
    My old car had the low fuel light permanently stuck on so I should be able to live with it lol
  15. Mar 22, 2011 at 9:42 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    well I keep my factory steel rims w/ sensors & winter tires in storage and get no light in the summer months. If the light triggers, like on my way to Maine, it resets overnight once I return home. My summer rims/tires have no sensors & have done mods except cover the light when it rarely triggers (long trips). :)
  16. Mar 22, 2011 at 3:19 PM
    lopezoscar03
    you could also just remove the sensor and put it on the new wheels. the wheel shop should be able to do this
