New wheels and TPMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mastiff37, Mar 5, 2021.
  1. Mar 5, 2021 at 7:01 PM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    If I get new aluminum wheels, do I really need to buy new TPMS sensors as it says on the tirerack website? And if so, do I really need to go to the dealer to get them set up?
  2. Mar 5, 2021 at 7:21 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    I see your truck is a 2011. The batteries in TPMS units typically last 10 - 12 years. Mine got flaky at 11 years and finally died last year (14 years!). Discount Tire will put new sensors on with tires and program them to the truck for about $60 per wheel. If you like TPMS function then I'd put new sensors in with your new tires.
    wi_taco and Mastiff37[OP] like this.
  3. Mar 5, 2021 at 7:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can buy new sensors on Amazon for about $20 each. Discount Tire or almost any other tire store will install them at no extra charge when you buy new tires. They just did so on my 2007 Tacoma Wednesday.
    These are the ones I bought for my Ford, same brand, but different frequency for my Tacoma. They are model specific, so you need to check carefully before ordering to make sure they fit YOUR truck. Some models require a sensor in the spare, my 2007 did so I had to order a 5th one for it.
    Amazon.com: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 200+ American Brand Models | Replacement for 9L3Z-1A189-A | Clamp-in | NX-S025-4: Automotive
    Battery life varies. I'm told 7-10 years is typical, but many do last longer. The sensors were still working on my nearly 14 year old truck, but I knew that they would be going bad soon. Since I was buying tires anyway it made sense to have new sensors. I didn't ask at Discount Tire about replacing just the sensors on a tire, but have been quoted $10 each from 2 different sources. It just makes sense to replace them when buying new tires if the old ones are around 7-8 years old
    My 2014 F150 will be getting new tires soon and I've already ordered new sensors for it, will be in Sunday or Monday. The truck is 7 years old and the sensors are still working, but most likely will be bad before I wear out the next set of tires.
    New sensors work out to an average of about $10/year. Not much more than a Value Meal from McDonalds once a year. I figure I can afford that
    Mastiff37[OP] likes this.
  4. Mar 8, 2021 at 11:26 AM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Many reviews that those don’t work, including one on a 2015 Tacoma. Looking for a set myself and don’t feel like paying $100 each from dealer. Selling old wheels with them in
  5. Mar 8, 2021 at 11:40 AM
    Pinion
    Drew
    Brookings Oregon
  6. Mar 8, 2021 at 11:48 AM
    Mastiff37
    Tucson, AZ
    I decided just to eat the $60/ea for the standard ones.
  7. Mar 8, 2021 at 12:00 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
  8. Mar 8, 2021 at 12:00 PM
    Pinion
    Drew
    Brookings Oregon
    Huf it’s in the link
  9. Mar 8, 2021 at 12:01 PM
    Pinion
    Drew
    Brookings Oregon
    I’ve decided to just swap over from old rims and put cheapies ack in old
  10. Mar 8, 2021 at 12:06 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I had the tire guy break the bead on my factory wheels and pull the sensors for my new ones. They had about 600 miles on them so they were good to go. I would use the factory ones and replace the batteries and seals. I put stems in my old set, aired them up and sold them. I told the buyer there were no sensors in them.
  11. Mar 8, 2021 at 12:07 PM
    steelcity2
    Pittsburgh Pa
  12. Mar 8, 2021 at 12:08 PM
    Pinion
    Drew
    Brookings Oregon
    Get batteries from stealer ship?
    Truck is a 2015, all state batteries are good for 6 or 7 yrs. would be wise to do batteries
  13. Mar 8, 2021 at 12:14 PM
    Pinion
    Drew
    Brookings Oregon
    Forget that, just saw what that entails, lol
  14. Mar 8, 2021 at 1:02 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Walmart will install new sensors for just over $20 each. They work.
  15. Mar 8, 2021 at 2:01 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    First off, the TPMS sensor batteries cannot be replaced. When they die it's time for new ones. If you want to have "Toyota" quality, the originals are actually Denso and Pacific Industries makes them for Denso. You can find them on Amazon in the $35 range, give or take.
    Keep in mind that there is a difference between steel and alloy wheel TPMS. The new TPMS will need to be "linked" to your truck. Any tire installer can do this or if you have a TPS scan tool you can do it yourself.
    CraigF, Muddinfun and Mastiff37[OP] like this.
  16. Mar 8, 2021 at 2:48 PM
    CPS-65
    Alta Loma, CA
    Mostly old man mods
    I didn't know that. Costco advertises a rebuild kit that includes batteries and seals they want you to purchase when they change out your tires.
  17. Mar 8, 2021 at 3:00 PM
    Pinion
    Drew
    Brookings Oregon
    You have to remove the silicone backing under the....... well, backing plate
  18. Mar 8, 2021 at 3:50 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    A typical TPS service kit....no battery. Cost $2-$5 ea.
  19. Mar 8, 2021 at 3:51 PM
    steelcity2
    Pittsburgh Pa
    I was also thinking u couldn't change the batteries.
  20. Mar 8, 2021 at 4:01 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    The sensors live in a rather hostile environment spinning, bouncing, vibration, heat & freeze cycles that it has to take a toll on the electronics. They might last 10 years and even if you could replace the battery, the smart money would be to replace the entire sensor and start fresh.
