New wiring behind exhaust heat shield - will it burn up?
Discussion in 'Lighting' started by iroc409, Dec 15, 2009.
  1. Dec 15, 2009 at 2:08 AM
    iroc409
    iroc409 [OP] Well-Known Member
    Washington
    A red one
    So, tonight I ran a set of 14-ga wires in some basic corrugated split loom from the engine bay to the back of the truck for some aux reverse lights I am intending to install, but I am a little worried. The best route for the loom was basically along the steel fuel lines on the driver's side, which runs right above one of the heat shields for one of the many cats in the exhaust system. I can't really tell, but it is possible the loom is actually touching the shield.
    Will I end up melting the wires this way, or will the heat shield keep enough heat away that it won't be an issue? I didn't really see any other way in running the wires, without going through the cab--which would be a lot more work.
  2. Dec 15, 2009 at 4:20 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    I've found that there is a nice space between the frame and body that works perfectly for hiding wires, air hoses, cb antenna wire, etc out of the way. a few zip ties and you're golden. i don't have and pictures, but if you get under your truck, it's pretty easy to find.
  3. Dec 15, 2009 at 10:53 AM
    iroc409
    Washington
    A red one
    OK, thanks, I will see if I can find it. I thought about going above the frame rail, but I wasn't sure how much the body moved and if it would pinch the wires. Hopefully I can find the spot and move it without re-doing the whole run, that was a pain in the rear.
  4. Dec 15, 2009 at 10:57 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    i ran my coax cable for my CB along the top of the frame. with a few zipties
  5. Dec 15, 2009 at 12:22 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    exactly. my coax is right there as well, with nothing protecting itand has been fine for over a year
  6. Dec 15, 2009 at 4:22 PM
    Lentsnh
    Just follow a gas line, brake line, or a harness set of wires and stick with that line you should be fine
  7. Dec 15, 2009 at 11:52 PM
    iroc409
    Washington
    A red one
    I pulled the wire out where it was and ran it back through, this time I ran it above the fuel lines instead of below. I think this should be OK, as it is not touching the heat shield and gives a better air gap. I also got it further away from the downpipe.
    I haven't done any automotive electrical stuff in a long time, this has turned into more of a project than I'd hoped (aux reverse lights and Lightforce 240's in the front). It should be worth it, though!
