New with Lift kit questions
Discussion in 'Suspension' started by SilverStreekTaco, May 30, 2008.
  1. May 30, 2008 at 11:21 AM
    SilverStreekTaco
    SilverStreekTaco [OP] New Member
    san jose
    08 access cab SR5
    hey guys whatsup just found this site from online and looks like a fun and active one.. I had some questions about getting a lift kit on my truck i was looking at the 3" toytec and was wondering if anyone has gotten the
    3" Pro Basic Kit or the 3” Lift Coil Kit with AAL
    i dont really know the difference between them but i know that i would like a smooth ride without any squeeking or noise coming from under my truck.. im kind of a picky guy and i hate hearing things that dont sound right. My style of riding is basically towing a boat and also putting dirtbikes in the back, i havnt ever taken my baby 4 wheeling but if i do it will be very minimum.
    What lift do you guys recommend?
  2. May 30, 2008 at 11:36 AM
    ShorelineFab
    ShorelineFab Ask for forgiveness than permission
    The O.C, CA
    2008 DBL CAB, BLACK, TRD SPORT, TSB/SUP/UPGRA
    Good question !
    I'm on stand-by to hear a response!:cool:
  3. May 30, 2008 at 12:19 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    The main difference between the two is that the Pro Basic kit uses spacers. The coil lift uses coils.
    The Coil lift (OME Coils) will give you better ride comfort and suspension travel than the spacer lift. But since you said that off roading is not a priority, the Spacer lift is more than adequate for your needs.
  4. May 30, 2008 at 5:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Get the coils. :)
  5. May 30, 2008 at 6:16 PM
    20taco07
    20taco07 Well-Known Member
    sacramento
    2007 toyota tacoma sr5 trd sport 4x4
    the coil lift is better by far and at the same time cost more, i wont ever put on spacers on my truck. they ruin the ride quality.
  6. Jun 8, 2008 at 2:22 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    +1 on the spacers. Doodoo! Get coilovers for the best ride.
  7. Jun 8, 2008 at 5:02 PM
    rick
    rick `
    no need to replace your shocks. other upgrades include (but may not be necessary) are uca's and diff drop. your pretty much good to go with a 3" lift and an alignment
  8. Jun 8, 2008 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. You do need to replace your shocks. The OEM shocks on the Tacoma cant control the 3" lift springs spring rate. You will top out like crazy.
  9. Jun 8, 2008 at 6:07 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    I've got the spacer lift because I wanted a stiffer ride (can it on the nasty thoughts guys :eek: )-- than stock--it was just too "cushy" for me, didn't ride like a truck. I'm very happy with the spacers, and couldn't afford the coils anyway, but now it rides more like a truck should! Still not as good as my 2000, but close. No squeaks or noise--I certainly wouldn't call my lift "doodoo."
  10. Jun 8, 2008 at 6:12 PM
    rick
    rick `
    he has the bilsteins. anyone else want to chime in on this?
  11. Jun 8, 2008 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. It doesnt mention that in his post, or profile. If they are the OEM Bilstiens, he SHOULD replace them as they are not valved for the OME springs. They will give a poor ride, with very little damping control. If he has the 5100 series Billies on the front, he should be fine then. :)
  12. Jun 8, 2008 at 6:21 PM
    rick
    rick `
    sure it does
  13. Jun 8, 2008 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO! I am BLIND!!!! :eek:
    Sorry. Regardless, the OEM Billies cant comfortably control the OME springs.
  14. Jun 8, 2008 at 7:05 PM
    gpspowell
    gpspowell Well-Known Member
    Denver, CO
    08 4WD TRD Off Road
    TRD Supercharger, TDR CAI, TRD Cat Back Exhaust, Old Man Emu 2 1/2" lift kit (886s & Dakars), Full All Pro armor inc. locker guard, Custom fuel tank armor, All Pro Rock Sliders, ARB front bumper, IPF 800XS Driving Lights, Ramsey REP 8000 winch, Centerline wheels, 285X75X16 Michelin LT AT2s, Snug Top shell, SoundLinQ audio interface for my iPod.
    No matter what you're running for suspension, for hauling loads and towing it's hard to beat a set of Air Lift levelers.
  15. Jun 8, 2008 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True. :)
  16. Jun 9, 2008 at 5:24 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have the toytec with the drops and factory trd shocks. No squeaks or problems with anything.
    Chris4x4 and or Rick - When you say 5100's does that refer to the factory Bilstiens or is that the aftermarket adjustable ones? If it is the factory billies what is it that is bad? Are they not long enough?
  17. Jun 9, 2008 at 7:22 AM
    bermise
    Houston
    08 TRD off road
    5100's refer to the aftermarket adjustable ones. A lot of people claim they ride much better than stock. And factory bilstiens ride really rough with OME lift, I have heard.
  18. Jun 9, 2008 at 4:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is absolutly correct. :)
  19. Jun 9, 2008 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    the 5100's are much different from the OEM. They have a larger oil capacity, and ( I was told from Bilstien) they have a poly top out bumper on the inside of the shock. Front 5100's come in a 3 position adjustable model. The OEM Bilstiens cant handle the spring rate on the OME springs. They are valved for the OEM Toyota springs. They can over heat and loose all damping ability when used with OME springs. :)
  20. Jun 9, 2008 at 4:47 PM
    rick
    rick `
    the trd bilsteins are fine and you can use them with a 3" lift. the bilstein 5100s are better. IMO
