Newb Amp Install Question
Discussion in 'Audio & Video' started by rod11, May 22, 2009.
  1. May 22, 2009 at 12:37 PM
    rod11
    rod11 [OP] Well-Known Member
    Baton Rouge, LA
    09 Pyrite Mica DC Prerunner TRD Sport
    This is probably going to sound ridiculous to most of you, but I want to verify something...can I install an amp without removing my door panels? I'm thinking of just connecting the speaker wire from the amp to the existing speaker wire behind the HU to limit the chances of me messing something up.
    If this is possible, is my sound quality going to noticeably suffer from using the stock wires? Since I've got to have speaker wire whichever way I go, how much do I need to run from the amp (behind back seat) to all 4 doors and a sub?
    Thanks!
  2. May 22, 2009 at 11:36 PM
    acozzens
    acozzens Well-Known Member
    98056 , washington state
    06 4d 4wd trd sr5 silver
    Michelin ltx m/s WSU (cougs) License Plate Holder $1.99 Gate Theft Mod DIY HU install DIY SWI-JACK install DIY rear speaker & baffle DIY ipod audio/video interface DIY HD radio DIY Alpine pdx 5 DIY front components install DIY RedLine Tuning Gas hood lift ( very slick ) DIY slimcubby gb hid head/fog DIY extang trifold trifecta DIY dynolock tailgate lock
    Yikes.
    I think it would be just as hard to do it ghetto style like you're considering. Why not remove your door panels ? I think there's more risk doing this what I consider the 'wrong' way.
    I think tapping into factory wires to increased the chances of something going wrong. I just did a full install and tapped into the steering wheel wires only.
    However, if you want to try it this way I'm sure it can be done. But I am not feeling it. On the flip side, it took me a long time to finish this project.
    I just feel it's a terrible waste of money and time if you don't do the basics correctly...Might not sound any better than stock in the end.
    In the meantime, cruise this audio-video section. I've personally posted damn near 100 photos, and there is some really good info in the sticky's and other people's posts.. Lots of good info right here.
  3. May 23, 2009 at 7:34 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    First off, copper is copper. The stock wiring will be adequate if you add an amp. However, I am not sure I understand why you would be doing this. I would not amplify stock speakers, as they do not have very high power handling. To add to that, amplifying the stock speakers is kinda like trying to polish a turd.
    If you add all new speaker wire (which I'd recommend) I'd buy 50' of something larger than 22 awg. I'd look for something in the 16-18awg for ease of placement.
  4. May 23, 2009 at 7:53 AM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    there's nothing wrong with doing it that way... If you have an aftermarket Head unit. then it is easy. all you have to do is bring in the new wires into behind the HU, and solder them up to the harness (if you were smart and got a wiring harness.)
  5. May 23, 2009 at 9:02 AM
    rod11
    Baton Rouge, LA
    Sooner, I have actually already had all of my door speakers replaced with kenwood after markets, so the amp will be pushing them and a single sub. Had this done at a local shop. I guess more of a concern than taking the door panels off is having to run the new speaker wire to the doors if it's not really necessary.
    So here's where I'm at...if the existing wire is adequate, then I'd like to save the trouble of accessing the doors. If it's going to sound noticeably better by replacing all of the wire, I'll tackle that b/c I do have 60' of 16 gauge wire ordered. What you think?
    I don't have enough background with this stuff to know whether an after market wire is going to sound better than the existing factory wire. I do understand after market is better quality wire, but if you can't tell the difference audibly then what's the point of replacing it???
    Mneuls, I'lll be connecting to the factory HU via a LOC.
  6. May 23, 2009 at 1:03 PM
    sooner07
    A A Ron
    DFW, Texas
    Aftermarket speaker wire, IMHO, will sound absolutely no different than any other speaker wire of the same gauge. Copper is copper.
    Your weakest link is most likely that LOC, so the brand or type of speaker wire you use should be of little concern. Heck, even if you have super high end speakers and HU and all that fancy stuff, speaker and power wires are still of very little significance.
    The reason that I like to run my own speaker wire is to make sure that there is nothing wired inline with the stock stuff that I may not be able to see. There might be a bass blocker (capacitor) wired in there at some spot that I didn't know about, and that would adversely affect the sound. I also like to take things apart and add fancy colored wire that has cool +'s and -'s on it so I know what is what.
  7. May 23, 2009 at 4:32 PM
    acozzens
    Good luck dude, let us know how it turns out..
    Now i'm curious !
  8. May 23, 2009 at 8:19 PM
    mneuls
    If you has some shielded 16ga beldin it might make a difference, but what's already there is the same as speaker wire. there would be no difference. just make sure your splice points are good and you'll be "a ok".
    PS If you are worried about sound quality, why do you still have the stock HU?
    Also, try not to run your rca's and speaker cables too close to the power cables for your amp, that will make a bigger difference than anything.
  9. May 23, 2009 at 8:51 PM
    sooner07
    A A Ron
    DFW, Texas
    Shielded speaker wire will make no difference.
    The stock HU can sound pretty decent with proper equalization.
    If it were possible to have less audible than shielding speaker cables, RCA cables next to the power wire would be it. It will have no effect on SQ nor will it induce noise.
  10. May 24, 2009 at 10:49 AM
    mneuls
    I would beg to differ on that point. DC power can be induced into rca's quite easily if they are side by side. It can cause alternator whine, and other interference, usually in the high range. This is solved by using higher voltage signal on the rca's or using a ground loop isolator.
  11. May 24, 2009 at 11:21 AM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    ive been installing for about 15 years. and i would definilty use the stock speaker wire and stock speakers for that matter. no reason to use new wire when you already have perfectly good wire in the doors already.
  12. May 24, 2009 at 12:44 PM
    sooner07
    A A Ron
    DFW, Texas
    Beg all you want, physics doesn't support your claims.
    If you are getting engine noise induced into your sound, it is not your power wire near your RCAs. Most likely, you have a grounding issue and a ground loop isolator can work to fix that. However in an automotive body with lots of steel around, there should be no need for that. Just make sure you have a clean grounding point with adequate wire and solid connections.
  13. May 24, 2009 at 1:33 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    If you are afraid to open your doors, then you do not want to use the stock wiring. You will be much better off running new wires. Either way, you are still going to run wires from the amp to the speakers or amp to behind the HU.
  14. May 26, 2009 at 1:03 PM
    rod11
    Baton Rouge, LA
    Thanks for all of the advice guys. As soon as my amp install kit arrives from knukonceptz I'm going to give it a shot just splicing in behind the HU. Hopefully I'll have good results to post in a few days.
  15. May 26, 2009 at 2:29 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    As long as you have solid connections to the stock wiring, you'll have no issues at all. There are a TON of myths and urban legends out there that spew out wrong information, you have to be able to sift through all the BS and get to the core of it....and it's been stated already several times by Sooner....copper is copper. For your application, you are good to go IMO.
    If you were willing to drive up here, I'd help you out no problem. Only about 4 hours north of you on I-49.
  16. May 26, 2009 at 5:10 PM
    rod11
    Baton Rouge, LA
    Thanks GoBlueFan. By the time I get done making a mess of things that 4 hour drive might not sound bad :)
  17. May 26, 2009 at 5:17 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Make a day of it...we'll have a great time. I got all the tools needed.
    I have my amp and speakers sitting on my table waiting for install. I want to get a head unit before installing it.
    Install party weekend?
  18. Jun 2, 2009 at 6:16 AM
    rod11
    Baton Rouge, LA
    GoBlueFan I finally got the amp installed this weekend. Took all freaking day but it's working and only a few minor scratches on the dash :) Now I just need that box to come in so I can hook up the sub for the finished product!
  19. Jun 2, 2009 at 7:19 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Good deal. Offer still stands if you ever need any help with this sort of stuff. Just yell.
    I hope to have the rest of my stuff to install by the end of the month. I plan on taking my time and doing everything at once (other than the deadening). Starting to get impatient.:D
  20. Jun 2, 2009 at 7:36 AM
    rod11
    Baton Rouge, LA
    I will. Appreciate it.
    What all are you waiting on? I had the amp sitting around my house for a month and couldn't wait anymore!
