Newb has a ?
Discussion in 'Towing' started by KickAss, Jul 7, 2008.
  1. Jul 7, 2008 at 3:58 PM
    KickAss
    KickAss [OP] Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    My 2005 taco is 4x4 longbed with tow package, I put my ballmount or drawbar in and locked it, but it seems awfully loose in the receiver itself, is this normal?
    I looked around but could not find any answers on the board.
    Thanks in advance
  2. Jul 7, 2008 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welconme to TW.
    Its normal. :)
  3. Jul 8, 2008 at 2:52 PM
    KickAss
    Chuck
    Florida
    Thanks Chris :)
    That sucks!
    is there a fix or specific type ball mount for the taco's?
  4. Jul 8, 2008 at 3:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, pretty normal. you can buy a clamp type thing to keep the receiver quiet, or drill and tap a hole in the top and use a bolt to tighten up against it.
  5. Jul 8, 2008 at 3:35 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Norma. It does this on my Taco. I've been considering just putting a little peice of rubber underneath it to quit it.
  6. Jul 8, 2008 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I use a peice of bicycle inner tube. About 1' take it and go from the top of the hitch around the back, and pull back under the hitch. I hope this makes sense. :)
  7. Jul 9, 2008 at 6:31 AM
    KickAss
    Chuck
    Florida
    thanks guys, hell I should figure something out and sell the damn things!
    I appreciate your input.
    Charles
  8. Aug 4, 2008 at 7:37 AM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    This was my original question.
    http://www.tacomaworld.com/forum/towing/4942-anti-rattle-hitch-device.html
    Check this link out, I know what you are talking about, after several tries with different devices I came out with this.
    Best Regards.
    THIS WAS MY FOUND SOLUTION, (with a small mod to it).
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/7897-anti-rattle-device-works.html
