Newb question about fitment and lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, May 2, 2012.
  1. May 2, 2012 at 3:05 PM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Hello all!
    Just got my 2010 DCSB SR5 4x4 Taco this weekend (first truck ever), and naturally, I'm already thinking about wheel/tire/lift combos. I have a few questions that will really help me decide which way I want to go with my truck as far as these mods...I tried to search for the answers, but I didn't have any luck. Sorry if it's somewhere obvious and I missed it!
    1. Will a 285/75/16 tire fit on the stock SR5 16x7 alloys? If so, do I need spacers to clear the UCA?
    2. Will the previous setup only fit with a 3" lift?
    3. Is anybody currently running 33"s on stock wheels, and is there an advantage to getting an aftermarket off road wheel? I'm not planning on rock crawling or anything extreme, just some mild to moderate trail riding.
    Thanks in advance! :D
    By the way, here is a pic of my truck/wheels from the dealer.
  2. May 2, 2012 at 4:08 PM
    dlg636
    dlg636 Active Member
    Darrin
    Honolulu, Hawaii
    4x4 Tacoma w/all the goodies
    DR front coils and rear shocks, deaver springs, load leveling airbags, k&n intake, JBA hedders and exhaust,Unichip power chip, URD short shifter, onboard air compressor, upgraded power inverter (1000W put in stock inverters location) budbuilt traction bar, warn transformer winch mount and warn winch, HID headlights and foglights, full LED bulb conversion, LED bed lights, full stereo system with GPS and they all roll on 16x8 black steel rock crusher and 285/75R16 BFG KM2's.
    hello, when i first got my truck i tried to run 285/75/16 BFG mud terrains on the stock wheels and it did rub the UCA alittle. as far as not putting a lift i don't think those will fit. at the time i was runnig a revtek 3" lift and i still had to do some trimming so the tires wouldn't rub. hope this helps.
  3. May 2, 2012 at 5:58 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Good luck!
  4. May 2, 2012 at 6:51 PM
    The Traveler
    SoCal
    Sweet, thank you!
