newbee w/06 5lug taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paul gallardo, May 21, 2008.
  1. May 21, 2008 at 10:38 PM
    paul gallardo
    paul gallardo [OP] rc racer
    northridge, ca
    5lug taco access cab
    fog lights,light bar, sport pedals, tire size swap(from 215/70/15 to 235/75/15to31/10.5/15). Crager 15x8 blackies 2.5 inch lift.Dynomax super turbo, AFE intake system.
    hello to everyone!!!
    I own an 06 5lug Taco. Its got a 2.5 leveling kit up front and an add-a-leaf w/ pro comp shocks in the back. I'm about to tackle a gear ratio change. From 3.31 to 4.11. Any advise would help. Its got 31 inch tires.
    thanks, paul
  2. May 22, 2008 at 1:48 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I'm assuming it's a prerunner?
  3. May 22, 2008 at 2:25 AM
    alextreme76
    alextreme76 Well-Known Member
    Tucson, AZ
    05 Reg Cab 4x4 5spd 265/70/16 Rugged Fails
    pics dude please? is this the black one from CT?
    why would you want 4.11 with 31s? good luck with it
  4. May 22, 2008 at 5:05 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Def post some pics man!
    5 Lug is a non-pre-runner. :thumbsup:
  5. May 22, 2008 at 9:20 AM
    paul gallardo
    northridge, ca
    I'll send some pix. It's a non-prerunner. Here's some stats: 2.5 leveling kit from a prerunner(by Daystar), Procomp add-a-leaf w/ a set of hellwig leaf spring helper, and Procomp ES3000 shocks. With 31 inch tires, the truck is somewhat bogged down. The original tire size was 26 inches and with 3.31 gear ratio. My home made intake system helps.
  6. May 22, 2008 at 11:24 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Have you calculated the rpms at speed with the 4.11s and 31's? How far off from stock does that work out?
    With the price of gas these days I'd hate to see you running gears that are too steep.
  7. May 22, 2008 at 1:14 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    i was curious about the daystar kit i saw one my friend had for 06 4wd he never used and it looked like it would work on my 07 5lug what if anything did you do to make it fit?
  8. May 23, 2008 at 12:03 AM
    alextreme76
    Tucson, AZ
    WOOOOO! you have a 6lugger leveling kit on a 5lugger? I almost got in a fist fight with someone that said this wouldnt work!
    Do you have part numbers to? You rock dude!
    Oh and I say download the Toyota service manual for torque specs and everything, I dont like Chiltons or anyone has a manual out yet for the newer Tacos
  9. May 23, 2008 at 6:30 PM
    paul gallardo
    northridge, ca
    Here's the part number for the leveling kit. ProComp 64302
    I think the add-a-leaf is also procomp. I'll try and see if I can find a part#
  10. May 23, 2008 at 6:42 PM
    paul gallardo
    northridge, ca
    Correction on the spacers. It's actually ProComp, part#64302. Its like doing a strut replacement. The kit provides you new "longer" bolts. Instructions will guide you through.
  11. May 25, 2008 at 12:30 AM
    alextreme76
    Tucson, AZ
    ahhh so its a polyurethane spacer with extended bolts, so was it trimmed to fit the narrower 5 lug strut bolts?
  12. May 25, 2008 at 10:22 AM
    paul gallardo
    northridge, ca
    No trimming needed. Everything bolts right in.
  13. May 25, 2008 at 10:28 AM
    paul gallardo
    northridge, ca
    It's about $200 bucks plus tax. You don't really need to replace the shocks.
    Here's the breakdown: Spacers=$80, Add-a-leaf=$50, shocks=$35 each. You can use the stock u-bolts for the add-a-leaf. Yes, I did the work my self. Don't know what the readylift go for.
  14. May 25, 2008 at 12:13 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    Your truck looks great. How do those 31"s workout? Did you have to do any trimming to fit them? Is there any rub? I'm surprised to see 31" tires on the stock rims.
  15. May 25, 2008 at 12:46 PM
    paul gallardo
    northridge, ca
    Thanks. The tires work great. It does rub on the sway bar on a lock-to-lock turn, I think its because of the rim offset. Some tire shop told me that the 31's won't fit on the stock rim, I guess that mystery is solve. I looking into aftermarket wheels. I'l keep you posted.
  16. May 25, 2008 at 6:19 PM
    alextreme76
    Tucson, AZ
    is it two pieces? an isolator on top of the coil over and a spring spacer inside the coilover? that would mean pulling the coilover a part right?
  17. May 25, 2008 at 10:09 PM
    paul gallardo
    northridge, ca
    Yes, you have to pull the coilover a part to be able to replace the stock bolts with longer ones. The spacers will just sit on top of the assembled strut assmebly.
  18. May 26, 2008 at 1:10 AM
    alextreme76
    Tucson, AZ
    oh man i really dont want to have to rent a spring compressor and deal with that mess :(
    thanks for all the info dude, sorry for this thread getting hijacked
  19. May 26, 2008 at 8:08 AM
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    Truck Looks Awesome What About Alignment Didi You Have To Realign?
  20. May 26, 2008 at 9:40 PM
    paul gallardo
    northridge, ca
    Thanks, just needs a standard wheel alignment( toe and camber). Around 50 bucks or so.
