Newbie and got a couple questions...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttran076, Mar 29, 2008.
  1. Mar 29, 2008 at 9:52 AM
    ttran076
    ttran076 [OP] Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
    Hey guys about to get a 08 dbl cab tacoma TRD Sport and had a few questions. I wanted to put a 3" Toytec lift with AAL. Would I need to get the suspension TSB or I could just use the Toytec kit only? And what would be the biggest tire size i could run for a 16" rim or a 18" rim? Thanks in advance!
  2. Mar 29, 2008 at 10:19 AM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Actually with most 3" lifts they use the current suspension components and actually tell you that you can't use their kits if you had the TSB done. The '08 models are not currently included on the TSB either.
  3. Mar 29, 2008 at 10:21 AM
    Dcrooks84
    Ohio
    Yeah, I just looked it up and the toytec lift kit is an add a leaf so you will not want to have the TSB performed.
