newbie here with header question
Discussion in '4 Cylinder' started by hondarida122, Dec 10, 2008.
  1. Dec 10, 2008 at 7:14 PM
    hondarida122
    hondarida122 [OP] Active Member
    Falmouth,MA
    08 tacoma
    I have a stock 08 tacoma 2.7l 4 cylinder. I just bought a K&N intake and magnaflow catback exhaust plus a urd short shift kit. I was wondering how much more power can you expect from Doug thorley's header and how hard is installation. I'm not going to bolt up the exhaust until I make up my mind on what to do. Thanks
  2. Dec 10, 2008 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you should get a fair amount of power from the header, and since its a 4 banger, install shouldnt be too bad either!
  3. Dec 11, 2008 at 7:00 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    You should see a 12hp and 11tq increase.
  4. Dec 11, 2008 at 8:11 AM
    hondarida122
    Falmouth,MA
    08 tacoma
    thanks a bunch it's on the way .
  5. Dec 12, 2008 at 6:57 PM
    Railwayrog
    Railwayrog Well-Known Member
    Amityville,NY
    07 Access Cab SR5 2x4,4 banger
    DT ceramic headers K & N series 77 cai DTRL Bull Bars ventshades tinted windows cup holder lights beefed up rear suspension PlasmaGlow FireStorm tailgate bar Access roll-up cover class 3 trailer hitch Box Bar (securing dirt bikes) Ready Ramp (ramp/bed extender) led bed light Redline hood struts JVC HD radio Cobra cb radio extra bed D rings OEM fog lights Gentex Electrochromic rearview mirror(compass/temp.,map lights)
    I just installed DT headers I bought off this board. Not tough if your mechanically incline.
    Don't reuse the stock bolt/spring set up like I did (hardware didn't come with it). You'll have to buy nuts and bolts for the header to bolt up to the middle pipe flange.
    Good Luck
    Roger
  6. Dec 13, 2008 at 10:25 AM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    so where do i get the new bolts and what size bolts do i need?
  7. Dec 13, 2008 at 10:58 AM
    Railwayrog
    Amityville,NY
    I can't remember off hand, I used the largest diameter stainless steel bolt (stainless nut & washer also) that would fit thru the flanges.
    Roger
  8. Dec 13, 2008 at 11:32 AM
    Zebra
    Millington, TN
    do these bolts need to be torqued?
  9. Dec 13, 2008 at 12:05 PM
    Railwayrog
    Amityville,NY
    I tried on the different Taco boards for a list of torque specs, no luck.
    With that size stainless nut and bolt you can tighten it nice and tight, I might have used lock washers in addition to the flat washers I used.
    I worry about torque settings too, especially on my dirt bike (I have a list of torque specs. for the dirt bike).
  10. Dec 13, 2008 at 1:59 PM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    If you bought it from URD, the header will come with bolts required for the header, you dont need to buy them.
