Newbie:Please help me choose my lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverHawk29, Oct 22, 2012.
  1. Oct 22, 2012 at 9:27 PM
    SilverHawk29
    SilverHawk29 [OP] Member
    Bay Area
    Silver 4X4
    Hello Tacomaworld,
    Newbie here and new to modding: I've been reading tons of posts on 3 inch lifts in this site but so far I still need some advice. I have a 09 DBL Cab TRD offRoad that I want to lift my truck 3 inches with 285/70 r17 Method Wheels double standard and in a few months or so put an ARB bumper on it as well. I've narrowed it down to 5100 Adjustable w Eibach front and Billies at the rear w AAL , or the ProComp lift kit which i've read is a pretty stiff ride. So far those 2 lifts are what fits my budget. So which one should I get in your opinion?. I won't really do much offroading maybe some really light trails is all as this is my daily driver.
    Can the Bilsteins go high enough to fit 285's and support the ARB bumper? I Don't mind doing trimming at all if needed. or should I just go with the Procomps and can they hold the ARB bumper? I've called other offroad shops and they said the Billsteins won't clear the 285's and support the ARB bumper.
    Your help would be greatly appreciated. Thanks!!
  2. Oct 22, 2012 at 9:32 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    do it right the first time.. OME with 886 front coils to support the ARB/winch any 3in lift you'll need upper control arms.
    you can still do a AAL in the rear.. or a dakar leaf pack would be the best
  3. Oct 23, 2012 at 1:05 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    ^ What he said!
    ARB makes OME & The 886s are for when you put one of there bumpers on a Taco.
    OME 886s will give you a much better ride than 5100 Adjustable w Eibach front (1.6" lift at 0 and 2.45" at .85" the highest recommended setting with Eibachs and that's with out an ARB bumper) for close to the same price.
  4. Oct 23, 2012 at 6:02 AM
    SilverHawk29
    Bay Area
    Silver 4X4
    So with the OME all around with an AAL and 886 I can still fit 285's with trimming and they won't look awkward with that ride height correct? Also what height of lift will that set up give me? Excuse my ignorance because i really want to get this lift right the first time.
  5. Oct 23, 2012 at 8:46 AM
    4Wheelin4Banger
    Randy
    I'm not sure about the 886s with an ARB as far as ride hight. I know there are a lot of guys running 285s with 886s & an ARB.
    I have the 885s & Dakars on 255/85/16 (33.3") with stock bumper (for now).
    This would be best asked in the suspension forum.
  6. Oct 23, 2012 at 8:48 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Get 886 / OME nitros , you will end up at 2 1/2 - 3" with the bumper on
  7. Oct 23, 2012 at 10:14 AM
    SilverHawk29
    Bay Area
    Silver 4X4
    Got off the phone with Wheelers offroad and he said with my budget on my lift kit I could go 5100s all around with an AAL and a top plate spacer on top to get close to 3" with an ARB bumper on. So basically I'm using a spacer to lift my truck? I thought spacers were not a good idea? Should I just get a revtek spacer kit instead since it will be the same but cheaper?
  8. Oct 23, 2012 at 2:34 PM
    2006KJ
    Front Royal VA
    save you $ for a few more months until you can guy a proper lift. nothing wrong with the 5100's but 5100's plus eibach's plus a spacer... i mean it's up to you. but it wont be half the quality in ride,handling,performance of an OME lift.
  9. Oct 24, 2012 at 8:29 AM
    4Wheelin4Banger
    Randy
    ^What he said.
    What did wheelers want for the 886s, OME nitros & an AAL?
  10. Oct 24, 2012 at 10:09 AM
    SilverHawk29
    Bay Area
    Silver 4X4
    So Ive decided to go OME complete kit from toytec. The Rep said since I am putting an ARB front bumper on I should go with 885 and a top plate spacer to stay at 3" instead of 886. Should I go with 885 or 886?
  11. Oct 24, 2012 at 10:35 AM
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    depends on the weight of the bumper, most use 886, its a heavy duty bumper that is the same length as the 885, but is for people running a heavy bumper up front.
    If you're going 3", you need UCA to do it right.
    OME is a great setup
  12. Oct 24, 2012 at 11:46 AM
    OZ-T
    Peter North
    British Columbia
    886's were designed specifically for the ARB bumper
    If you go 886's you should go with OME shocks
  13. Oct 24, 2012 at 12:13 PM
    SilverHawk29
    Bay Area
    Silver 4X4
    So since i plan on getting an ARB bumper soon I should go with 886 correct? No need for a top plate spacer right?
  14. Oct 24, 2012 at 12:16 PM
    OZ-T
    Peter North
    British Columbia
    I would get the 886's and no top plate spacer
    Get the OME 5mm trim packer for the driver's side shock to combat taco lean though
    You are getting OME front shocks right ?
  15. Oct 24, 2012 at 12:17 PM
    4Wheelin4Banger
    Randy
    Rep doesn't know what he's talking about. Like OZ said get the 886 it was made to go with that bumper.
    I have the 885s on my 4Banger AC without spacers or ARB bumper and got 3" lift.
  16. Oct 24, 2012 at 12:40 PM
    SilverHawk29
    Bay Area
    Silver 4X4
    Yah I kinda got that vibe. So i would just tell them I want the 5mm trim packer? Thanks for all the advice fellas
  17. Oct 24, 2012 at 12:53 PM
    OZ-T
    Peter North
    British Columbia
    Yes , OME 5mm trim packer
    It only works with OME shocks , it mounts on the driver's side shock below the coil perch
  18. Oct 24, 2012 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    This
  19. Oct 24, 2012 at 12:59 PM
    SilverHawk29
    Bay Area
    Silver 4X4
    The OME I'm getting is the 9000 Sport Shock is that ok?
  20. Oct 24, 2012 at 1:05 PM
    OZ-T
    Peter North
    British Columbia
    Yep
    I have the 885x / 90000 front / N182 rears with Dakar set up
    I likey
    I don't have an ARB up front though
