Newbie wanting to learn about gear ratios and tire sizes
Discussion in 'Wheels & Tires' started by Buffco, Jun 16, 2011.
  1. Jun 16, 2011 at 6:55 PM
    Buffco
    Buffco [OP] Well-Known Member
    Hello all. I am the almost new owner of a 92 Yota, 4wd, 5 spd tranny... It has 31" tires on it. I don't know if the current owner has any idea what he has in the rear end.
    What I don't know or understand is gearing for larger tires.
    1. What comes stock in that model?
    2. What do you look for in gear ratio as far gas mileage? Driveability? Off roading capability?
    3. When people speak of changing gear ratios, are they talking about the rear only in 4wd trucks? Or is there something to do to the front as well?
    Please be gentle. Whoever gives the most complete and extensive information will be rewarded with their choice of UFIA or boobage.
    Thanks.
  2. Jun 16, 2011 at 7:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    1. Your gearing can be found using the axle code on the door sticker and cross referencing it here
    http://www.4x4wire.com/toyota/faq/vin/
    2. The bigger the tire, the bigger the ratio the better the truck will be able to transfer power to the rear wheels (within reason).
    3. You should change the front in a 4x4 otherwise you cannot use the 4x4 function without breaking something.
  3. Jun 16, 2011 at 7:09 PM
    Buffco
    Well on your way to victory. Thanks for that.
    Question on number 3... You should change the front......"to what?" You match the front gear ratio to the rear, is that what you mean?
  4. Jun 16, 2011 at 7:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, they have to match gear ratio's.
