Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Feb 25, 2022 at 4:21 PM
    #201
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Closer to 89 octane.
  2. Feb 25, 2022 at 4:22 PM
    #202
    Kevinpd325
    Kevin
    San Diego
    She does what she's told and likes it.
  3. Feb 25, 2022 at 4:33 PM
    #203
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Our partner that did this run is not from the states. His regular octane fuel is closer to 89 than it is 87.
  4. Feb 25, 2022 at 6:29 PM
    #204
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Hi honey
    Kevinpd325 likes this.
  5. Feb 25, 2022 at 6:36 PM
    #205
    Mooseditty17
    AJ
    WI
  6. Feb 25, 2022 at 6:39 PM
    #206
    Chadr7858
    Chad
    Colorado
    Miss u
  7. Feb 25, 2022 at 6:45 PM
    #207
    Kevinpd325
    Kevin
    San Diego
    There's a name I haven't seen in a while!
  8. Feb 25, 2022 at 6:45 PM
    #208
    Mooseditty17
    AJ
    WI
    Kevinpd325 and Chadr7858[QUOTED] like this.
  9. Feb 25, 2022 at 6:46 PM
    #209
    Mooseditty17
    AJ
    WI
    Stranger Danger... :boink:
    Kevinpd325[QUOTED] likes this.
  10. Feb 25, 2022 at 6:49 PM
    #210
    Chadr7858
    Chad
    Colorado
    Lurking in the shadows like your uncles
  11. Feb 25, 2022 at 6:50 PM
    #211
    Chadr7858
    Chad
    Colorado
    How's it been going? I've been out of the tuning world for some time now.
    Mooseditty17[OP] likes this.
  12. Feb 25, 2022 at 6:53 PM
    #212
    Mooseditty17
    AJ
    WI
    Not too shabby. Life is good. Developing the next big thing with a couple of fellas. Remodeled an old farm house (not advised). Finally out of town and on an 80 acre parcel. Kids growing up too fast. You?
  13. Feb 25, 2022 at 7:03 PM
    #213
    Chadr7858
    Chad
    Colorado
    Same thing different day. Trying to rush through the rest of the winter so I can go sleep in the mountains again. But on the other hand... snow can be fun. I'm excited to see this next big thing.
    ktbell444 and Kevinpd325 like this.
  14. Feb 25, 2022 at 7:08 PM
    #214
    Mooseditty17
    AJ
    WI
  15. Feb 25, 2022 at 7:12 PM
    #215
    Chadr7858
    Chad
    Colorado
  16. Feb 25, 2022 at 7:14 PM
    #216
    Chadr7858
    Chad
    Colorado
    When does vtec kick in?
  17. Feb 25, 2022 at 7:58 PM
    #217
    ownubad
    ownubad Well-Known Member
    Cory
    2017 Silver Sky OR
    Drop in AFE Pro Dry Filter Inchannel Vent Visors Bedlinered Rear bumper and plastic flares
    Ehh, I got recommended this little forum to follow and so far I am loving all the comments and feedback. I am a canadian owner with over 100k miles and shes a 6000lb 33 x 10 tire taco! She was running ovtune 2.0 33 thx PREM for 2 years and about 30k miles, more maybe. Great tune, mat did great and well obviously everything updates within average of 6 months so I am need of a upgrade. Yall haven't done full premium logs yet and you got this much going on with 87-89? Hollllllyyyyy shiet! Im stoked to see more from you guys. I had the OFT handheld that was available back in 2019 area and so im sittng with STOCK garbage tuning and omg what a difference that is and so I'm waiting for my cable to be shipped and then to be switched over to vftuner and then i can get rocking with you guys! Heres the last good pull i did with my truck, on ramp going up, cold and slightly wet lol. Keep up the great work. Im also CanadianOffroad4x4 YT and IG
  18. Feb 25, 2022 at 8:07 PM
    #218
    SpeySquatch
    2016 TRD OR DCSB
    Wow! Those 33’s make quite the difference. I did a 5.8sec 0-60 tonight with 32’s and 4.88’s (truck is about 5,500lbs) from a stop. This tune just GOES.
    you may want the +P version
  19. Feb 25, 2022 at 8:19 PM
    #219
    Kevinpd325
    Kevin
    San Diego
    Squatch we have heard your cries and are working like mad to make her better. We'll find the balance.
    ownubad and Mooseditty17[OP] like this.
  20. Feb 25, 2022 at 8:21 PM
    #220
    Kevinpd325
    Kevin
    San Diego
    It don't come on and dip like it used to that's for sure. We're aiming for balance and clean delivery throughout. Nice arc on the dyno, but I think the next one should be better.
    ownubad and shotgunbilly420 like this.
