Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Feb 26, 2022 at 1:07 PM
    #241
    ownubad
    ownubad Well-Known Member
    Cory
    2017 Silver Sky OR
    Drop in AFE Pro Dry Filter Inchannel Vent Visors Bedlinered Rear bumper and plastic flares
    Should be illegal for 2wd trucks to be made in canada haha, yes 4wd. Im a TRD OR. One of the first 17s on the lot when i bought in oct 2016.
  2. Feb 26, 2022 at 1:36 PM
    #242
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Tundra TB is on my list also thanks to you. Lol
    ownubad[QUOTED] likes this.
  3. Feb 26, 2022 at 2:00 PM
    #243
    gwynn1975
    gwynn1975 Well-Known Member
    2018 Tacoma
    Chevy 63 swapped 35’s Custom dents
    I’m in Yelm and can get you set up with Nexus
  4. Feb 26, 2022 at 4:50 PM
    #244
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Thanks buddy :thumbsup:
    Kevinpd325 and BortisYeltzen like this.
  5. Feb 26, 2022 at 5:37 PM
    #245
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Your welcome
    Kevinpd325 likes this.
  6. Feb 27, 2022 at 5:35 AM
    #246
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    You will absolutely love low 4 on Nexus!
  7. Feb 27, 2022 at 5:45 AM
    #247
    Mooseditty17
    AJ
    WI
    I'm going to assume if he's on my thread he's NOT looking for a KD tune. You don't see me on KD page pushing Nexus. Let's keep it PG13 here please.
    whh2063, oldtoyman and SpeySquatch like this.
  8. Feb 27, 2022 at 6:11 AM
    #248
    shotgunbilly420
    My apologies I thought he is looking for someone to flash nexus for him .
  9. Feb 27, 2022 at 6:18 AM
    #249
    Mooseditty17
    AJ
    WI
    @gwynn1975 is the distributor for Nexus in that area. PNW does not sell Nexus.
    oldtoyman and gwynn1975 like this.
  10. Feb 27, 2022 at 6:45 AM
    #250
    shotgunbilly420
    I will remember that from now on
  11. Feb 27, 2022 at 9:53 AM
    #251
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Thank you
    gwynn1975 likes this.
  12. Feb 28, 2022 at 4:17 PM
    #252
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    I'm interested in this tune but curious how it would handle 85 octane fuel? I live in CO and my cheap ass goes with the lowest octane available.
  13. Feb 28, 2022 at 4:25 PM
    #253
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    If your elevation is high enough where the air is less dense, then 85 octane will absolutely be just fine.
  14. Feb 28, 2022 at 4:25 PM
    #254
    oldtoyman
    Kevin
    North of Seattle
    Little math for my area is 87 vs 91 is .30 cents. 20 gal fill up = $6.00 more for premium. Then fill up every week for a year is only $312 more per year.
    gwynn1975 and shotgunbilly420 like this.
  15. Feb 28, 2022 at 4:25 PM
    #255
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I'm in co also running 85. So far it's been amazing.
  16. Mar 1, 2022 at 5:43 PM
    #256
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    No 91 here, it's either 87, 89, or 93. The math for me is $.60 more a gallon, or $12 for a full tank. I've got about 300 miles on Nexus + premium and it looks like I'm averaging about 1.5 more miles per gallon. At $4 a gallon (Current price for 93 here, higher tomorrow, last station I saw with that price so I topped off) I can subtract $5.80 from $12 for a true cost difference between 87 and 93. Right now the satisfaction of driving Nexus + premium is worth $6.20 a fill up.
  17. Mar 1, 2022 at 5:51 PM
    #257
    shotgunbilly420
    What's the weight of your truck and tire size? Also you regeared?
  18. Mar 1, 2022 at 5:53 PM
    #258
    MLee
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    All stock, no add ons or changes. I know, boring........
  19. Mar 1, 2022 at 6:24 PM
    #259
    shotgunbilly420
    Well any information is helpful. Far as gearing I'm stock just trying to find someone that's similar to my setup so I can get best opinion of the nexus premium+
    MLee[QUOTED] likes this.
  20. Mar 1, 2022 at 6:39 PM
    #260
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    Were you on stock tune before Nexus or a different tune? Have you noticed any strange behaviors with nexus like dead pedal or not wanting to shift out of 4th gear or anything else?
