Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Mar 26, 2022 at 11:48 AM
    #481
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    I had the same thought when I saw the dyno
    shotgunbilly420 likes this.
  2. Mar 26, 2022 at 11:51 AM
    #482
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Every Dyno graph on TW is likely only while doing a WOT pull. Not sure what makes our tune any different than others regarding your comment. Especially if 99% of your time is under 3k RPM's... No Dyno graph will apply to your driving if that's the case.
  3. Mar 26, 2022 at 12:06 PM
    #483
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
  4. Mar 26, 2022 at 12:18 PM
    #484
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
  5. Mar 26, 2022 at 12:32 PM
    #485
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
  6. Mar 26, 2022 at 12:36 PM
    #486
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Dude he's literally responding to the post above his that assures us EVERY tune's dyno on TW begins at 3k.
    Anyway, would you like to fill me in on the cruise control behavior?
    D. Lengua and BortisYeltzen like this.
  7. Mar 26, 2022 at 12:39 PM
    #487
    Kevinpd325
    Kevin
    San Diego
    Message me your specific questions and I will address.
  8. Mar 26, 2022 at 12:39 PM
    #488
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
  9. Mar 26, 2022 at 12:47 PM
    #489
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    @skeletron
    I took your post as asking for someone who has purchased the tune for their experiences, and to avoid any potential biased answers, I opted to avoid answering your question as I'm not a buyer. If I'm mistaken, I'll gladly provide my experiences.
    skeletron likes this.
  10. Mar 26, 2022 at 12:49 PM
    #490
    Kevinpd325
    Kevin
    San Diego
    Gotcha. Well, I'm the hill runner of the development team. I've been refining CC lately, but my truck is currently down for maintenance. Getting it to not want to shift to on minor inclines has been the goal lately. In its current form it does okay. It's imperfect in my eyes, but that's also the goal. Which has been the goal for every aspect of the tune... perfection. Which is why we say it's still in development. We aren't there yet. Pretty close, but this ain't horseshoes.
    We will provide updates as discussed above, and are still actively looking at things discussed previous in this thread.
    skeletron[QUOTED] and PhogDog like this.
  11. Mar 26, 2022 at 1:18 PM
    #491
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Personally I think it would be helpful to hear from developers, testers, and paying customers on this one
    ktbell444[QUOTED] and PhogDog like this.
  12. Mar 26, 2022 at 1:36 PM
    #492
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I wasn’t calling this one out in particular, although it had a relatively high min rpm. It was more of a general observation of dyno graphs I’ve seen for the 3.5 that aren’t particularly speaking to me. The most interesting thing I see in these graphs is the smoothing out of the 4k dip. I do experience that when towing and when I’m in a spirited mood.
  13. Mar 26, 2022 at 1:47 PM
    #493
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I enjoy it. 2.0 was pretty bad with adaptive cruise (that's all I use by the way, not standard cruise control). I would constantly get stuck in 5th gear going 79 down the interstate. Nexus has not been this way for me. Where I live is pretty flat, except for overpasses and bridges across rivers. I'll typically downshift to 5th, as needed, as well as 4th sometimes. But I haven't got stuck.
    From what I know about Dyno's, the recording is based on when the Dyno operator presses the record button. More modern Dyno's may not be that way, or maybe it's based on the manufacturer? I'm not exactly sure on that. Maybe others with more experience could chime in on that.
  14. Mar 26, 2022 at 5:49 PM
    #494
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    FCL30, Chadr7858 and 758_Moto like this.
  15. Mar 26, 2022 at 5:55 PM
    #495
    Mooseditty17
    AJ
    WI
    Team Nexus would love to have ya der hey.
    ktbell444 likes this.
  16. Mar 26, 2022 at 5:57 PM
    #496
    Mooseditty17
    AJ
    WI
    We are aiming to have MT complete this summer. Mid to late June is our goal. Life outside of tuning has been less cooperative lately.
    Kevinpd325 likes this.
  17. Mar 26, 2022 at 5:58 PM
    #497
    Mooseditty17
    AJ
    WI
    It's not as good as when driving, but is significantly improved over stock. I personally don't use cruise control, but I'm sure there are a few out there tuned with Nexus that can give you their two cents on it.
    ownubad likes this.
  18. Mar 26, 2022 at 6:53 PM
    #498
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    *Edited as it’s not worth arguing about a tune I’ve bought and tested (+P).
    Best of luck to you all.
  19. Mar 26, 2022 at 7:39 PM
    #499
    Mooseditty17
    AJ
    WI
    :cheers:
  20. Mar 26, 2022 at 7:43 PM
    #500
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Pretty sure a banned member here paid you to purchase it as they hid in the shadows. Vehicle was purchased and currently registered in the state of California.
