Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. May 20, 2022 at 10:56 PM
    #621
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Thanks for the review! I'm curious how your manual calculations compared to what your truck calculated. I've never personally hand calculated my MPG's.
    The stock files for all currently supported vehicles are located within the install directory of vF Tuner.
    egb1776[QUOTED] likes this.
  2. May 21, 2022 at 10:16 AM
    #622
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    Perfect, thank you. As for the calculations, between stock, 2.0b ovtune and now your tune I’ve been generally within 1+\- mpg when the tire diameter is factored in vs the dash readout. Winter time is usually off abit more because of increased idle time. This computer seems on a whole more accurate than my Cummins which is always 2-4mpg optimistic.
    ktbell444[QUOTED] likes this.
  3. May 22, 2022 at 2:53 PM
    #623
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I’ll be back mid June…..
  4. May 22, 2022 at 11:24 PM
    #624
    CO_Taco125
    CO_Taco125 Well-Known Member
    '17 TRD OR DCSB
    Blackhawk Tune, Falken Wildpeaks, Falcon Suspension, KMC XD, KC flexpods, KC Pro6 bar, Kicker speakers, Sound Ordnance sub, MTX amp, interior vinyl wrap
    Any update on when the MT tune will be available? I have a buddy with a '19 Pro who's interested.
  5. May 23, 2022 at 11:14 AM
    #625
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Fairly soon. We are working on finalizing some huge updates that will include MT options. Tests are in-progress.
  6. May 23, 2022 at 11:15 AM
    #626
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Let's ride. I want to send some more night creek crossings at high speed...
    johntoyota[QUOTED] likes this.
  7. May 23, 2022 at 11:20 AM
    #627
    MountainManGuy
    Colorado
    So I've got a few thousand miles on the tune(+P non premium) and found it really likes 87 octane as opposed to 85, even at elevation. I've ran quite a few tanks on both and I'm getting an extra 2-3 MPG on 87 vs the 85
    Mooseditty17[OP] likes this.
  8. May 23, 2022 at 2:26 PM
    #628
    hkdtaco
    hkdtaco Active Member
    WA
    2018 Cement Tacoma TRD Sport 4x4
    Blackhawk Tune, KING 2.5, RRW, 295/70R17, S&B
    Will there be a charge for the update?
  9. May 23, 2022 at 2:35 PM
    #629
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    If you've already purchased, no.
    Bastek, hkdtaco[QUOTED] and Gmak621 like this.
  10. May 23, 2022 at 4:13 PM
    #630
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    Excellent.
    Can't wait.
  11. May 27, 2022 at 10:22 AM
    #631
    johntoyota
    Down yonder in TN
    16 truck
    Unless I can fit my truck in my carry on I’ll be truckless.
    ktbell444 likes this.
  12. May 28, 2022 at 7:32 PM
    #632
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    The first post has been updated!
    The Nexus team heard what the customers wanted and collaborated with YotaWerx, the group that brought you the greatest FI tune to the 3GT market! This collaboration produced a superb tune, dubbed Blackhawk! You wanted a manual transmission tune? Check! You wanted smooth power throughout the entire RPM band? You got it! You wanted more low end torque? Hold my beer and say no more!
    Those of you who legitimately purchased M+W Nexus from us, you will have the option to update to this new tune free of charge. If you do wish to update, please hold off until the release, or until otherwise noted, before submitting a request as we do not want to overlook any previous customer from now until the release date.
    We not only greatly appreciate YotaWerx and their team, but we also appreciate to a great extent the feedback from customers, as well as the testers between Nexus and YotaWerx. All of those mentioned accumulated hundreds, if not thousands, of combined man hours to get this tune to where it is as of today. The hard work from each and every one of you is what makes the Nexus name have true meaning.
    FCL30, S2KON2, Taco_Rex and 3 others like this.
  13. May 28, 2022 at 8:11 PM
    #633
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I guess I legitimately purchased tunes, how do I get files? Thanks
    Kevinpd325 and ktbell444[QUOTED] like this.
  14. May 28, 2022 at 8:40 PM
    #634
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Of course Vlad. :hattip:
    We will either open requests at release, or shortly before release. Expect us to post when we are ready. We opted to have previous customers request rather than us go ahead and just send out the new tune to all previous customers. This will eliminate any added work on our end from creating new files for those who may have sold their 3GT or who may be content with their current tune, whether that's M+W Nexus or an alternative.
    PhogDog likes this.
  15. May 28, 2022 at 9:26 PM
    #635
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Ahhh yeah! Can’t wait to give it a whirl
    Kevinpd325 and ktbell444 like this.
  16. May 28, 2022 at 9:31 PM
    #636
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    I'm very happy with nexus, so looking forward to Blackhawk
  17. May 28, 2022 at 10:06 PM
    #637
    MountainManGuy
    Colorado
    Does this just add manual transmission support or are there improvements for the auto guys out there too? I've got an auto with Nexus +p. Just wondering if this updated tune is worth flashing.
  18. May 28, 2022 at 10:14 PM
    #638
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Oh, the AT tune is radically different.
  19. May 29, 2022 at 7:24 AM
    #639
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '25 DCSB Sport
    Stoked! Been running the PREM NA (3.0.5) tune for a couple weeks now. My truck loves it! Low end torque is incredible! Smooth thru the RPMs. Drivability is SOOOO GOOD! Can't wait for BLACKHAWK. I'm like a kid waiting for school to be out for the summer!
    Kevinpd325, ktbell444 and mZiggy like this.
  20. May 29, 2022 at 10:21 AM
    #640
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I've got a few thousand miles on my Nexus +P Premium tune now and it has driven flawlessly from the start. Good low end power, shifts perfectly every time under every condition, haven't experienced dead pedal or getting stuck in gear once like i did on almost every incline with KDMax Pro, and even with 33's on stock gearing it holds 6th gear better than it did stock. My worst tank with +P Premium has been 16.8mpg with a lot of city driving and every other tank has been over 18mpg with mixed driving. With KDM Pro I was getting 290-300 miles a tank and with +P Premium I'm getting 350+ miles.
    Can't wait to try the new Blackhawk tune when it's released!
